Parameter space for the negative binomial distribution
5 replies · 3K views
Mogarrr
For the negative binomial distribution, with r known, describe the natural parameter space
the pmf for the negative binomial distribution with parameters r and p can be
1) [itex]P(X=x|r,p)= \binom {x-1}{r-1}p^{r}(1-p)^{x-r}[/itex] where [itex]x=r,r+1,...[/itex], or
2) [itex]P(Y=y|r,p)= \binom {y+r-1}{y}p^{r}(1-p)^{y}[/itex] where [itex]y=0,1,...[/itex].
A distribution, like the one above where r is known, is a member of the exponential family of distributions. An exponential distribution is one that can be expressed as...
[itex]h(x)c^{*}(\eta) exp(\sum_{i=1}^{k} \eta_i t_i(x))[/itex]
The parameter space are the values of [itex]\eta[/itex] such that [itex]\sum_A h(x) exp(\sum_{i=1}^{k} \eta_i t_i(x)) < \infty[/itex] where [itex]A[/itex] is the support of the pmf.
Rewriting the 2nd pmf for the negative binomial distribution, as an exponential distribution, I have
[itex]h(y) = \binom {y+r-1}{y}[/itex], [itex]c(p) = p^{r} \cdot I_(0,1)(p)[/itex], [itex]t_1(y)=y[/itex], and [itex]w_1(p) = ln(1-p)[/itex].
Then I let [itex]\eta = w_1(p)[/itex], and find the values for [itex]\eta[/itex] where the sum converges.
I have [itex]\sum_{y=0}^{\infty} \binom{r+y-1}{y}(e^{\eta})^{y}[/itex], and I don't recognize this sum as anything that converges.
Any help would be appreciated.
[tex]\frac{1}{(1-z)^r} \equiv (1-z)^{-r} = \sum_{k=0}^{\infty} \binom{r+k-1}{k} z^k.[/tex]
The reason for the name "negative binomial distribution" is that it comes from "negative binomial coefficients" ##\binom{-r}{k} = (-1)^k \binom{r+k-1}{k}## associated with the "negative binomial" series ##(1-z)^{-r}##. You ought to be able to show that the series converges for ##|z| < 1## because it just generalizes the series for ##1/(1-z)##.
That look's like a winner.
I had thought of using the 1st pmf for the negative binomial distribution. Then I'd have the exponential distribution as:
[itex]h(x) = \binom {x-1}{r-1} \cdot I_{(r,r+1,...)}(x)[/itex], [itex]c(p) = p^{r} \cdot I_{(0,1)}[/itex], [itex]t_1(x) = x-r[/itex], and [itex]w_1(p) = ln(1-p)[/itex].
Then letting [itex]w_1(p) = \eta[/itex] and solving the series for [itex]\eta[/itex]:
[itex]\sum_X \binom {x-r}{r-1} e^{(x-r)\eta} = \sum_X \binom {x-r}{r-1} (e^{\eta})^{x-r}[/itex],
then I recognized this series: [itex]\sum_{x=r}^{\infty} \binom {x-1}{r-1}w^{x-r} = (1-w)^{r}[/itex].
So I have [itex](1-e^{\eta})^r[/itex].
I'm not sure, but I think the constraint is that [itex]|e^{\eta}| < 1[/itex].
Is this right?
Is this right?
I cannot make any sense out of what you write above.
Your previous post had a simple, explicit question, and I answered it. If you put ##z = e^{\eta}## you will get the summation you had in your first post, and I already pointed out what restrictions apply to ##z##.
Thanks for your first reply. I thanked you for it.
Maybe my reply was lengthy and ambiguous. I asked you about the constraints for w in this series,
[itex]\sum_{x=r}^{\infty} \binom {x-1}{r-1} w^{x-r} = (1-w)^{r}[/itex], which I found at this webpage.
I think it's the same series you gave, with a change in the index, letting [itex]x=y+r[/itex], I have
[itex]\sum_{y=0}^{\infty} \binom {r+y-1}{y} z^{y} = \sum_{x=r}^{\infty} \binom {x-1}{x-r}z^{x-r} = \sum_{x=r}^{\infty} \binom {x-1}{r-1}z^{x-r}[/itex]
My question is this: Is the webpage wrong?
Looking at the negative binomial distribution as a particular case of the general binomial series, I see the formula on the webpage was wrong.
Note to self: do not trust all websites.
