A Partial derivative of composition
The discussion revolves around the proper interpretation of the partial derivative of a function C(x, y) where y is a function of x. One participant argues that the gradient operator with respect to x, denoted as ∇_x, should only involve the partial derivative of C with respect to x, evaluated at the specific values of x and y. Another perspective introduces the need to consider the function g(x) = C(x, y(x)), which leads to a different derivative expression that includes the derivative of y. The conversation highlights the importance of clarity in defining which function is being differentiated and the implications of treating C as a function of multiple variables. Ultimately, the participants emphasize the necessity for unambiguous notation to avoid confusion in mathematical expressions.
SchroedingersLion
Hi guys,
suppose we have a function ##C(x, y)## into the real numbers. Suppose also that ##y=y(x)##, i.e. ##y## is a function of ##x##.
Now in my script, I have a term ##\nabla_x C(x_0, y(x_0)) ##. From my point of view, this means that you take the partial derivative of ##C(x,y)## with respect to x and then insert ##y(x_0)## for ##y##, and ##x_0## for ##x##.
I would not consider the x-derivative of ##y(x)##, since then the subscript at the nabla operator wouldn't make any sense as this would simply be ##\nabla C(x_0, y(x_0))##.
Is this line of thinking correct?
Best
SL.
Mathematics news on Phys.org
I agree.
I would interpret the last expression as vector with the two partial derivatives as components.
Likes SchroedingersLion
Hi guys,
In this case you must be careful about what function you are talking about and how you are differentiating. Technically, you have now defined a new function of a single variable:
$$g(x) = C(x, y(x))$$
And, the derivative of ##g## is given by:
$$g'(x) = \frac{\partial C}{\partial x}+ \frac{\partial C}{\partial y}y'(x)$$
It would make no sense, of course, to take the gradient of ##g##. And:
$$g'(x_0) = \frac{\partial C}{\partial x}(x_0, y(x_0)) + \frac{\partial C}{\partial y}(x_0, y(x_0))y'(x_0)$$
However, you have another function which is the gradient of ##C##:
$$\nabla C = \frac{\partial C}{\partial x} \hat x + \frac{\partial C}{\partial y} \hat y$$
Note that this function is also a function of two variables. And, you can now define another function by:
$$h(x) = \nabla C(x, y(x)) = \frac{\partial C}{\partial x}(x, y(x)) \hat x + \frac{\partial C}{\partial y}(x, y(x)) \hat y$$
And, of course:
$$h(x_0) = \nabla C(x_0, y(x_0)) = \frac{\partial C}{\partial x}(x_0, y(x_0)) \hat x + \frac{\partial C}{\partial y}(x_0, y(x_0)) \hat y$$
In the context of your question, therefore, you need to decide which function you are dealing with: ##g## or ##h##.
Thanks for the responses!
The two of you seem to disagree about my own interpretation what to do.
@PeroK
I should have noted that ##x## and ##y## are each in ##R^d## so the partial derivatives should be gradients.
From your explanations, I still don't see what the subscript then means in ##\nabla_x##. If ##C(x, y(x))## implies the redefinition of ##C(x,y)## as a function ##g(x)##, then the subscript of the gradient would be useless, right?
Therefore, my original idea:
@PeroK
Okay, so you actually have a function of two vector variables: ##C(\vec x, \vec y) = C(x_1, x_2, x_3, y_1, y_2, y_3)##.
There's the same issue. Are you first reducing ##C## to a function of a single vector ##\vec x##, using ##\vec y = \vec y(\vec x)##? Or, are you taking the gradient of ##C## with respect to ##\vec x## and then plugging in ##\vec x_0, \vec y_0##?
Which one of these it is depends on the context of what you are doing.
That's essentially what I don't know. I had hoped there was some clear convention =(
I don't think it's a matter of convention. It's a matter of the author being unambiguous. You should be able to work out which one it is from what follows.
