Partial derivative of Lagrangian with respect to velocity
The discussion focuses on the derivation of the partial derivative of the Lagrangian with respect to velocity, specifically the equation $$\frac{\partial L}{\partial \dot{q}}=p$$. The first derivation shows that for the Lagrangian $$L=\frac{1}{2}m\dot{q}^2-V$$, the result is $$\frac{\partial L}{\partial \dot{q}}=m\dot{q}=p$$. However, a second approach using the expression $$L=\frac{1}{2}\dot{q}p-V$$ leads to the incorrect conclusion that $$\frac{\partial L}{\partial \dot{q}}=\frac{1}{2}p$$. The discussion emphasizes the necessity of applying the product rule correctly in such derivations.
  • Understanding of classical mechanics principles
  • Familiarity with Lagrangian mechanics
  • Knowledge of calculus, specifically partial derivatives
  • Ability to apply the product rule in differentiation
  • Study the derivation of the Euler-Lagrange equation
  • Explore advanced topics in Lagrangian mechanics
  • Learn about the implications of the product rule in physics equations
  • Investigate the relationship between momentum and velocity in classical mechanics
Students and professionals in physics, particularly those specializing in classical mechanics, as well as educators teaching Lagrangian mechanics and calculus.
Adel Makram
I came across a simple equation in classical mechanics,
how to derive that?
On one hand,
so, $$\frac{\partial L}{\partial \dot{q}}=m\dot{q}=p$$
On the other hand,
$$L=\frac{1}{2}m\dot{q}^2-V=\frac{1}{2}m\dot{q}\dot{q}-V=\frac{1}{2}\dot{q}p-V$$
which is half value from the first derivation.
how to derive that?
On one hand,
On the other hand,
Well, writing \frac{1}{2}m \dot{q}^2 as \frac{1}{2}\dot{q} p doesn't change anything; you have to use the product rule:
\frac{\partial}{\partial \dot{q}} \frac{1}{2} \dot{q} p = (\frac{\partial}{\partial \dot{q}} \dot{q}) \frac{1}{2} p + \frac{1}{2} \dot{q} (\frac{\partial}{\partial \dot{q}} p)
Likes Adel Makram
that is true.
Adel Makram said:
that is true.
Well, if p = m\dot{q}, then \frac{\partial}{\partial \dot{q}} p = m
  • · Replies 24 ·
