Partial Fractions - irreducibility question
4 replies · 1K views · last reply
RJLiberator
1. x^2-x+1
Is this factorable?
My initial thinking is NO. However, I can complete the square and it becomes (x-1/2)^2-3/4, but this doesn't seem to help me. Would this be considered factorable?
2. Turn 1/x^2-x+1 into partial fractions
Clearly, after I answer #1 correctly, #2 will be more clear. But under my initial assumption that #1 is NOT reducible, then how would I turn 1/x^2-x+1 into a partial fraction?
I am getting 1 = Ax+b where b = 0 and A = 1/x but that doesn't seem at all correct.
Thanks for any guidance / help.
RJLiberator said:
1. x^2-x+1
Is this factorable?
You have an error in your work. You should have (x - 1/2)2 + 3/4, not (x - 1/2)2 - 3/4. This quadratic is not factorable into factors with real number coefficients.
This expression needs parentheses around the entire denominator. What you wrote is this:
$$\frac{1}{x^2} - x + 1$$
No, it's not. The coefficients A and B should be constants, not expressions that involve a variable.
BTW, what happened to the homework template? You should not delete its parts.
Fair enough.
Do I use the denominator of x^2-x+1 or (x-1/2)^2 +3/4 to use partial fractions?
RJLiberator said:
Fair enough.
You don't turn ##\frac 1 {x^2-x+1}## into a partial fraction. In the second form above, where you have completed the square, it is already ready to integrate using an arctangent.
LcKurtz, thank you my brother for the help verifying my thoughts.
