Particle filter for Pedestrian Dead Reckoning
  • Thread starter Thread starter ravishah
    Filter Particle
The discussion focuses on implementing a particle filter for Pedestrian Dead Reckoning using MATLAB, emphasizing the use of mobile accelerometer sensors to track steps and stride length for distance calculation. The main challenge is developing a motion model and integrating accelerometer and orientation readings to enhance accuracy. Participants express interest in sharing progress and insights on the implementation process. There is a call for collaboration and updates on ongoing work in this area. Overall, the thread highlights the need for practical guidance in applying particle filtering techniques to improve pedestrian tracking accuracy.
ravishah
Hi,
I am working on Pedestrian dead Reckoning using Particle filtering in matlab, I am using mobile accelrometer sensor to detect number of steps and stride length and calculating the total distance travelled. I want to use particle filter to enhance accuracy in my results. I have read the theory of particle filter but stuck at the point that how to implement it in matlab, How I can develop motion model, ,I have accelerometer and orientation reading as measurement. The output can be position of the object, anyody have some idea. And how to integrate it with map.
regards
ravi
i am also doing work in this area, but this thread is old: are you still working on this? did you make any progress?
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
