Particle in a box wave function
26 replies · 25K views
ProPatto16
for a wave function confined between x=0 and x=L find an expression for A in order that the wave function be normalized
for a particle in a box between 0 and L the normalized wave function is integral of C2sin2(n[tex]\pi[/tex]x/L).dx = 1
using trig identities this results in C2L/2 so then C = sqrt(2/L)
also C = 2iA so equate equations for C for an ewuation to A
2iA = sqrt(2/L)
so A = (sqrt(2/L)) / 2i
squaring both sides gives A2 = (2/L) / (-4)
then this gives A to be a sqrt of a negative number. do i just use i?
so then its A= (1/2L)i ??
then i need to find probability that the particle is in the ragion 0<x<L/4 ? with no expression for x?
No. The wave function is [itex]\psi(x) = C \sin(n\pi x/L)[/itex]. To be properly normalized, it must satisfy
[tex]\int_0^L \psi^*(x)\psi(x)\,dx = \int_0^L C^2 \sin^2\left(\frac{n\pi x}{L}\right)\,dx= 1[/tex]
Right, so the normalized wave function is
[tex]\psi(x) = \sqrt{\frac{2}{L}} \sin\left(\frac{n\pi x}{L}\right)[/tex]
also C = 2iA
Where did this come from?
2iA = sqrt(2/L)
Aside from the fact you don't need to do any of this, you already had an expression (not an equation) for A, so why did you square it only to take the square root (incorrectly) to find what A equaled?
What do you mean "no expression for x"?
oh. i see. it looks like i started doing it from one part of the textbook then finished it with parts of another section :/
the second integral you have there. sqrt(2/L)sin(npix/L)... shows that A = sqrt(2/L)
then for the probability thing... take integral of wave function squared between 0 and L/4?
integrating sqrt(2/L)sin(pix/L) between L/4 and 0... i can't use latex so ill do my best. also i have an image here and it shows n=1 that's why i left it out.
so integrating with respect to x
[sqrt(2/L)cos(pix/L) between L/4 and 0
[sqrt(2/L)cos(piL/4/L] - [sqrt(2/L)cos0]
(sqrt(2/L)(cospi/4) - sqrt(2/L)
and cos(pi/4) = sqrt2/2 = 0.707
so 0.707sqrt(2/L) - sqrt(2/L) = ahhhhh 0.293
i see. i minused them the wrong way round.
that better?
probability would be 0.293A?
oh. amatuer mistake! -.-
1/4 + 1/L ...
well see i had that thought too but then i wasnt sure if the probability depended on L..
but i redid the integral and got 1/4 this time. but that doesn't seem right either because the probability isn't evenly distibuted so i would of thought it can't be 1/4 for L/4...
1/4 has to be right. I am confident on my integration!
also, I've noticed while doing these integrals, that the probability doesn't depend on n for L/4. because no matter what value n takes you still end up taking the sin of a whole integer multiplied by pi... which is always 0. so does this mean the probability is the same for all n between L/4 and 0?
and then that means that all probabilities for all domains between 0 and L must be independent of n?
going on that, if i change n to 2 and then graph between 0 and L, it shows very obviously the area under the curve between 0 and L/4 is indeed 1/4...
You're not integrating correctly. You were right when you suspect 1/4 wasn't right because the probability density isn't uniform.
If you just post an incorrect answer, all I can tell you if it's right or wrong. I can't see what mistake you're making unless you show your work.
Squaring function gives (2/L)sin^2(pix/L) then using trig identity it becomes (2/L)*1/2(1-cos(2pix\L) then 1/L(1-cos(2pix/L) then multiply 1/L through gives (1/L-(cos(2pix/L)/L) then integrating gives x/L-sin( 2pix/L)/L^2 then subbing in L/4 gives L/4/L + 0 and subbing in 0 gives 0. So that simplifies down to 1/4...
[-cos(2pix/L)]/L becomes L^-1[-cos(2pix/L)] so then take L^-1 out front cause it's constant, leaving integral of -cos(2pix/L) which gives (2pix^2/2L)sin(2pix/L) which becomes (pix^2/L)sin(2pix/L)... Then bring L^-1 back in giving [(pix^2/L)sin(2pix/L)]/L
No, that's not the right integral. Do you remember how to integrate functions of the form cos(ax)? The integral should be sin(ax)/a, which you can check by differentiation.
By the way, you can always check integrals using Wolfram Alpha: http://www.wolframalpha.com/input/?i=integrate+1/L*[-cos%282pix%2FL%29]dx
Failing that, you can always check them by differentiating the result and seeing if it's the same as the original value.
ProPatto16 said:
Gah. I give up :'(
I think you should review calculus. It's absolutely essential to physics, and quantum mechanics classes usually involve lots of tedious integration.
That substitution is what I thought I did. But I did just find a big mistake I've been making. So I'll try redoing everything from the start
So I get to this.
1/L*[x-(sin(2pix/L)/2pi/L)
Now subbing in L/4 for x gives sin(pi/2) =1 so
1/L*[L/4-(1/(2pi/L))
1/L*(L/4-L/2pi)
1/4-1/2pi
That's only correct for n=1, because you used (2/L)sin^2(pix/L) instead of (2/L)sin^2(n*pi*x/L). What's the general solution, for arbitrary n?
BTW sorry for missing that error earlier.
I have an image along with the question that shows n=1. a wave function that only has nodes at x=0 and x=L showing n=1. that's why I omitted it.
Okay. Thanks a lot. And yes. I've alreAdy started making a list of tips and hints for differentiation and integration.
