Find Particular Solution for x = 120 cos 6t
In summary, there are two methods for finding a specific solution for an equation like x = 120 cos 6t. The first method involves finding the general solution to the associated homogeneous equation and then using differentiation to guess the form of the solution. The second method involves using the general solution to the associated homogeneous equation to find a solution of a specific form. Both methods require solving equations to determine the values of certain variables.
Abdul.119
73
how can I find the particular solution for something like this
x = 120 cos 6t
I know how to find a particular solution for equations like x''+x'+x=0, you can easily find the characteristic equation then find the particular solution, but I have no idea how to deal with an equation like that..
Are you sure you wrote the problem down correctly? The equation you've given does not have to be solved. It already gives x unambiguously in terms of t. What did you imagine a solution would look like?
If you mean, say, a differential equation of the form x''+ x'+ x= 120 cos(6t), there are a number of different ways to find a "specific solution" to the entire equation. Two methods are given in any differential equations textbook. You should start by finding the general solution to the associated homogeneous equation, x''+ x'+ x= 0. That has, as you say, characteristic equation [itex]r^2+ r+ 1= 0[/itex] which has solutions [itex]r= \frac{-1\pm i\sqrt{3}}{2}[/itex]. That, in turn, tells us that the general solution to the associated homogeneous equation is [itex]x(t)= e^{-t/2}\left(C_1\cos\left(\frac{\sqrt{3}}{2}t\right)+ C_2\sin\left(\frac{\sqrt{3}}{2}t\right)\right)[/itex].
As I said, there are a number of ways of finding just one function that satisfies the entire equation. The two covered in textbooks are "undetermined coefficients" and "variation of parameters".
The first requires that you use what you know of differentiation to guess the general form of the solution. Here, since we know that the derivative of sine and cosine always give sine and cosine again, we "guess" a solution of the form x(t)= A cos(6t)+ B sin(6t). Take the first and second derivatives of that, put them into the equation and determine the values of A and B that will satisfy the equation.
The second does not require that you be able to guess the general form but is more complicated. Knowing the general solution to the associated homogeneous equation, we look for a solution of the form [itex]x(t)= e^{-t/2}(u(t) cos(\sqrt{3}t/2)+ v(t)sin(\sqrt{3}t/2))[/itex]. Finding the first and second derivatives of that and putting them into the equation will give two separate equations for u' and v'. Solve those for u' and v' and then integrate.
1. What is the general formula for finding a particular solution to a differential equation?
The general formula for finding a particular solution to a differential equation is to first solve the homogeneous solution (the solution when the right-hand side of the equation is equal to 0) and then add a particular solution (a specific solution that satisfies the original equation) to it.
2. How do you find the homogeneous solution for a differential equation?
To find the homogeneous solution, set the right-hand side of the equation to 0 and solve for the dependent variable. This will give you the general form of the solution, which can be written as a linear combination of exponential functions.
3. What is the particular solution for x = 120 cos 6t?
The particular solution for x = 120 cos 6t is x = 120/36 cos 6t = 10/3 cos 6t. This can be found by substituting the values of the coefficients and the independent variable into the general form of the solution.
4. How do you check if a particular solution is correct?
To check if a particular solution is correct, substitute it back into the original differential equation and see if it satisfies the equation. In this case, substituting x = 10/3 cos 6t into the equation x' + 36x = 0 will result in 0 = 0, showing that the particular solution is indeed correct.
5. Can there be more than one particular solution for a differential equation?
Yes, there can be more than one particular solution for a differential equation. In this case, the general solution will be the sum of the homogeneous solution and all possible particular solutions. This is because a differential equation can have multiple solutions that satisfy the equation.
  • Differential Equations
