Partition Function Homework: Find En at 290K
  • Thread starter Thread starter lmanri
    Partition
To find the partition function Z at 290 K for a system where the energy of the nth state is En = n(0.01 eV), the equation Z = ∑e^(-βEn) is used, with β = 1/(kT). The challenge arises from unit compatibility, as energy is given in eV while the Boltzmann constant is in J/K. Converting the Boltzmann constant to eV/K (8.625 x 10^-5 eV/K) resolves the issue. Once units are aligned, the partition function can be calculated using the series sum formula.
lmanri
Consider a system at 290 K for which the energy of the nth state is En=n(.01 eV). Using 1+a+a2+a3...=1/(1-a) for a <1 where necessary, Find the value of the partition function.
Z=∑e-βE_{}n
β=1/κT
I don't know what the energy of the state would be so I can't figure out the problem.
What do you mean you don't know what the energy of the state is? You wrote it already: E(n) = (0.01 eV)*n. It is linear in n.
So, I would then have
Z=(sum)e^(-(1/((1.38*10^-23)(290)))(n(0.01))
No. You have incompatible units.
Likes 1 person
I don't understand it.
tman means, your units of energy is in eV, but your Boltzmann constant is using units of J/K. You should convert one or the other to have the same units.
Likes 1 person
Oh ok, which is 8.625*10^-5 eV/K
