Need help with unique integer partitions?
The discussion focuses on generating unique integer partitions of a given integer N into M distinct parts, emphasizing the need for strictly positive and non-repeating elements. Participants suggest implementing a function that can systematically generate these partitions without excessive recursion, proposing alternatives like enumerating increasing sequences or using a next_partition function for efficiency. A specific example is provided, illustrating how to shift elements to create new partitions. The conversation concludes with one user successfully coding a solution after overcoming initial difficulties with function implementation. This highlights the complexity of the problem and the collaborative effort to find an effective programming approach.
rsq_a
This is causing me a bigger headache than I anticipated.
Basically, given an integer N and a number M, I need a list of all the possible integer partitions of N into M parts such that each part is strictly positive and each part is UNIQUE. I don't want repetitions. Just unique ones.
So for example, with N = 10 and M = 2
1 + 9
2 + 8
3 + 7
4 + 6
are the only possibilities.
I tried to write a code to do it, but just ran into huge headaches because of the necessary recursion. With M > 2, you need to worry about systematically shifting the sequence as you go. Can anybody make a suggestion?
Mathematics news on Phys.org
You forgot 10 = 5 + 5...
What do you mean by "systematically shifting the sequence"?
Anyways, you might want a third variable. You want a function
partitions(N, M, B)
that returns all partitions of N that have exactly M parts, each of which is smaller than B.
Hurkyl said:
You forgot 10 = 5 + 5...What do you mean by "systematically shifting the sequence"?
partitions(N, M, B)
It's not just the number of partitions I want. It's the actual list of elements. Also, I forgot to mention above that I need partitions in which element is repeated only once.
So if I wanted to do m = 4, N = 20, I'd need to do:
Shift the 2-last
1 + 2 + 3 + 14
1 + 2 + 4 + 13
1 + 2 + 5 + 12
Shift the 2nd number up
1 + 3 + 4 + 12
1 + 3 + 5 + 11
1 + 3 + 6 + 10
Shift the 2nd number up again
1 + 4 + 5 + 10
1 + 4 + 6 + 9
1 + 4 + 7 + 8
1 + 5 + 6 + 8
Shift the 1st number up
2 + 3 + 4 + 11
...And so on. Can someone recommend an easier way to do this in terms of implementation into a program? The above requires some really annoying recursive loops.
Shift the 2-last
1 + 2 + 3 + 14
1 + 2 + 4 + 13
1 + 2 + 5 + 12
1 + 3 + 4 + 12
1 + 3 + 5 + 11
1 + 3 + 6 + 10
1 + 4 + 5 + 10
1 + 4 + 6 + 9
1 + 4 + 7 + 8
1 + 5 + 6 + 8
2 + 3 + 4 + 11
What's wrong with exactly what you said? No recursion is necessary; each time you want to move to the next partition, you simply work from the end to figure out which number needs to be increased... and I don't see what's so annoying about a recursive implementation of the same method.
Oh, by the way, it might be easier to enumerate equivalent things, such as:
The list of all increasing sequences of M-1 numbers whose sum S is less than N - {the last number}​
Or even
The list of all sequences of M positive numbers such that the sum x1 + 2x2 + 3x3 + ... + MxM = N​
This latter one is formed by taking the deltas in a partition and reversing the order: e.g. the deltas of the partition (2, 7, 16) would be (2, 5, 9), and reversing would be (9, 5, 2). And you can check 9 + 2*5 + 3*2 = 2 + 7 + 16.
Better yet,
The list of all sequences of M nonnegative numbers such that the sum x1 + 2x2 + 3x3 + ... + MxM = N - M(M+1)/2​
This one has subtracted one from each entry, so that they start counting at 0 instead of 1.
Generalizing a bit...
Rather than a function that enumerates all partitions, it might be better to write the following function
int next_partition(unsigned int *start, size_t len);
which, assuming that the len-long array start is a partition, will replace it with the next partition, and return 1. (Or return 0 if you're already at the last one)
It might be easier to think through how to write this function properly, and it's probably a lot simpler to use in an actual program.
If you don't care about computer cycles then you could use Mathematica (or some other high-level language) and say:
Code:
Input:
f = Function[{n, m},
   Select[Sort /@ IntegerPartitions[n],
    Length[#] === m && Union@# === # &]
f[10, 2]
Output:
{{1, 9}, {2, 8}, {3, 7}, {4, 6}}
Thanks for the help. I finally wrote the code to do it (~30 lines).
Funny. It took me ages to wrap my head around how to use functions of functions in a computer program. First time for everything, I guess.
