I Rod Near Event Horizon: What Would Happen?
Cato
If I passed within one meter of the event horizon of a supermassive black hole (where the tidal forces are trivial) and stuck out a two meter rod such that one meter of the rod was inside the event horizon, what would I see happen to the rod?
You can't. The event horizon is not a place in space; it's an outgoing light ray. So your implicit mental model of what is happening in this thought experiment is not correct.
Also, if by "passed within one meter" you are thinking that you could somehow pass one meter above the horizon on a free-fall trajectory that then escaped back to infinity, that's not possible. AFAIK all such trajectories get pulled into the hole. So if you're imagining being within one meter of the hole without falling in, you have to "hover" using rocket power.
Under the conditions you've specified, you can model things as if you were a Rindler observer with a Rindler horizon one meter below you. (Note that this assumes you are "hovering" above the hole, not passing close to it--see my second note above.) So in a spacetime diagram of a local inertial frame in which the origin ##t, x = 0, 0## is an event on the horizon, your worldline would be a hyperbola ##x^2 - t^2 = 1##, where the units of ##x## and ##t## are meters. The worldline of the horizon in this frame is the 45 degree line ##x = t##.
If we now imagine the rod as being two meters long, and you extend it below you, you have a problem: as soon as the lower end of the rod is 1 meter below you, it is on your Rindler horizon and would have to move at the speed of light to keep up with you. Which it can't. So at some point before that, the rod will break. The reason it breaks is simple: you are exerting enormous rocket power in order to "hover" 1 meter above the horizon. That rocket power is pulling extremely strongly on the rod--so strongly that when the lower tip of the rod is 1 meter below you, the force exerted on the rod can't travel along the rod fast enough to keep the lower tip attached to the rest of the rod. So basically your rocket power pulls the rod apart.
In the spacetime diagram, you would draw the worldline of the rod's lower tip as gradually diverging from yours--say it starts at ##t, x = 0, 1## (where the units are meters), i.e., on your worldline, but then moves in the ##x## direction slower than you do, so its worldline is a shallower curve than the hyperbola you are following. At some point, the tip will cross the line ##x = t##, i.e., the horizon, and at that point the tip can't keep up with you, no matter how hard you pull on it.
OK, thanks so much for the detailed and really useful discussion.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
