Uniqueness of PDE Solutions: Investigating the Heat Equation
  • Thread starter Thread starter muzialis
    Pde Uniqueness
muzialis
Hi All,
I am dealing with the heat equation these days and in an attack of originality I thought I would find a new solution to it, namely
(dT/dt)=d^2T/dx^2
has a solution of the type
T(x,t) = ax^2+2t
Now, I do not know much about the existence and uniqueness of PDE solutions, but for some reason I though the existence of solution other than the one found by, e.g., variable sepration, was refused for this PDE. The Cauchy -Kowalewskaya theorem does not say much, it seems to me, until the boundary considtions are fixed.
Does anybody has a clear grasp on the matter, for which I would be the most grateful?
Many thanks
Regards
Muzialis
Uniqueness only applies to well posed problems. A PDE without boundary conditions is ill posed.
For a given PDE without boundary conditions, there are either infinitely many solutions or no solutions.
You should also note that in your case your solution is only a valid solution if a = 1.
(Moving to the Mathematics forums)
Hootenanny,
thank you for your valuable reply.
Best Regards
Muzialis
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
