Particle of Mass M Moving in XY-Plane: Potential Energy & Orbit Analysis
Reshma
A particle of mass M is free to move in the horizontal plane(xy-planne here). It is subjected to force \vec F = -k\left(x\hat i + y\hat j\right), where 'k' is a positive constant.
There are two questions that have been asked here:
1] Find the potential energy of the particle.
\vec \nabla \times \vec F = 0
The given force is conservative and hence a potential energy function exists.
Let it be U.
F_x = -\frac{\partial U}{\partial x} = -kx
F_y = -\frac{\partial U}{\partial y} = -ky
U(x,y) = \frac{k}{2}\left(x^2 + y^2) + C
2]If the particle never passes through the origin, what is the nature of the orbit of the particle?
I am not sure what the PE function tells about the trajectory of the particle. Explanation needed...
The potential energy can be used to find the Lagrangian, and then Lagrange's equation can be used to find the motion.
Alternatively, m \ddot{x} = F_x = -kx and m \ddot{y} = F_y = -ky[/tex] can be solved directly.<br /> <br /> These equations should look very familiar.<br /> <br /> Regards,<br /> George
<br /> <br /> Thank you for replying.<br /> <br /> So this is a 2-dimensional harmonic oscillator. The general solution would be:<br /> x = A\cos(\omega_0 t - \alpha) &amp; y = B\cos(\omega_0 t - \beta)<br /> <br /> So, the resultant path of these two SHMs would be an ellipse, right?
x = A\cos(\omega_0 t - \alpha) & y = B\cos(\omega_0 t - \beta)
Yes.
Regards,
George
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
