Peak Voltage vs magnet position in an A.C generator
The voltage in an A.C. generator coil reaches its peak when the coil is directly opposite the magnet, as this position allows the conductor to cut through the densest part of the magnetic flux. As the magnet begins to uncover the coil, the voltage decreases to zero, confirming that the coil generates voltage only when it interacts optimally with the magnetic field. The shape of the magnetic field significantly influences the voltage output, as the angle at which the conductor cuts the magnetic lines affects the induced voltage.
  • Understanding of electromagnetic induction principles
  • Familiarity with A.C. generator operation
  • Knowledge of magnetic field shapes and their effects
  • Basic grasp of voltage and current relationships in circuits
  • Research the principles of electromagnetic induction in detail
  • Study the design and operation of A.C. generators
  • Learn about the effects of magnetic field orientation on voltage generation
  • Explore the mathematical relationships governing induced voltage in coils
Electrical engineers, physics students, and anyone interested in the principles of A.C. generators and electromagnetic induction.
jearls74
I have a question about a magnets position over a coil of wire in an A.C generator. Is the voltage in the coil at Peak as long as its covered by the magnet? and then the voltage starts to decrease to 0 volts as the magnet starts uncovering the coil until the magnet totally uncovers the coil and the voltage is at 0 volts, is this right?
You would have to know the shape of the magnetic field.
In this simple example,
[PLAIN]http://dl.dropbox.com/u/4222062/magnetic%20field.PNG
You can see that the wire (shown as an orange circle) is in a magnetic field even though the magnet is some distance away.
Even though the wire is cutting lines of magnetic flux, they are not at right angles to the direction of movement, so the voltage being generated is less than when the wire is directly opposite the magnet and when the lines of magnetic flux are at right angles to the direction of movement.
your peak voltage is generated as your conductor passes through the densest part of the magnetic flux.
  • · Replies 28 ·
17K
  • · Replies 26 ·
