How Does Pendulum Speed Change with Angle and Initial Velocity?
  • Thread starter Thread starter Shackleford
    Momentum Pendulum
The discussion revolves around calculating the speed of a pendulum bob at its lowest position and determining the minimum initial velocity required for the pendulum to swing to a horizontal position. The calculated speed at the lowest point with an initial speed of 8 m/s is 8.35 m/s. For the pendulum to reach the horizontal position, the minimum initial speed required is 4.33 m/s, as the final kinetic energy will be zero at that point. Participants clarify that the value of 8.35 m/s is not applicable for the second part of the question. The conversation concludes with a user expressing confidence in solving the problem after a brief pause.
Shackleford
[SOLVED] Pendulum Momentum Question
Figure 8-34 shows a pendulum of length L = 1.25 m. Its bob has speed v0 when the cord makes an angle theta0 = 40 degrees with the vertical.
What is the speed of the bob when it is in its lowest position if v0 = 8 m/s?
The speed is 8.35 m/s.
What is the least value that v0 can have if the pendulum is to swing down and then up to a horizontal position?
W + KE1 + PE1 = KE2 + PE2
W + KE1 + PE1 = KE2 + PE2:
0 + (1/2)m(8.57 m/s)^2 + 0 = (1/2)m v^2 + m(9.8 m/s^2)1.25m
v= 6 or 7 something. The answer in the book is 4.33 m/s
Use 8.35 m/s.
physixguru said:
Use 8.35 m/s.
Sorry. I forgot to put the 8.35 in there. But, it still doesn't give me the correct answer. I get 6.74 m/s.
The final kinetic energy will be zero when the pendulum reaches the horizontal when considering the minimum initial velocity.
The 8.35m/s does not apply here, since that value is based on the first part of the question and is irrelevant to this part. You are trying to find the velocity of the pendulum needed at 40 degrees to the vertical that will just get you to the horizontal position on the other side.
Oh, hello! Man. I know I can work it now. I'll do it after I eat. lol.
Got it. Thanks. Sometimes, I just read over the problem too quickly and assume I read it correctly.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 26 ·
  • · Replies 27 ·
