Percent Difference Between Two Number
wahaj
I am a bit embarrassed to ask this question as I can do multivariable calculus but I can't seem to figure out this simple percentage question. My professor calculated percent difference using two different formulas and I am can't figure out what the difference is between the two. Here are the formulas
error = \frac{larger value - smaller value}{larger value} X 100
and
error = \frac{larger value - smaller value}{smaller value} X 100
can anyone explain where the second formula would be used because so far I've only used the first formula.
Mod note: The % signs were fouling up the LaTeX, so I removed them. Office_Shredder must have removed them in what he copied.
Mathematics news on Phys.org
and
It depends on whether you're interested in the percent change of the larger or smaller number. For example if the government deficit is 500 billion dollars, then grows to 600 billion dollars, it grew by 100/500*100 = 20 percent. If it was 600 billion dollars, then shrunk to 500 billion dollars, then it shrunk by 100/600*100 = 16.6 percent.
[STRIKE]I get what you are trying to say. One more question, if I wanted to find the greatest percent difference between the two numbers I would use the second formula?
[/STRIKE]
[edit] never mind I figured it out.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
I'm interested to know whether the equation $$1 = 2 - \frac{1}{2 - \frac{1}{2 - \cdots}}$$ is true or not. It can be shown easily that if the continued fraction converges, it cannot converge to anything else than 1. It seems that if the continued fraction converges, the convergence is very slow. The apparent slowness of the convergence makes it difficult to estimate the presence of true convergence numerically. At the moment I don't know whether this converges or not.
