Perfectly Elastic Collision Problem
In a perfectly elastic collision problem involving a 110 g ball and a 400 g ball, the conservation of momentum and kinetic energy must be applied to find the final velocities. The initial velocities are 4.0 m/s for the 110 g ball and 1.2 m/s for the 400 g ball. The discussion highlights the need for two equations: one for conservation of momentum and another for conservation of kinetic energy. Participants express confusion over the calculations and the correct application of these principles, particularly when dealing with simultaneous equations. Ultimately, the solution involves using Galilean transformation to simplify the problem by treating one ball as stationary.
jonnejon
A 110 g ball moving to the right at 4.0 m/s catches up and collides with a 400 g ball that is moving to the right at 1.2 m/s.
If the collision is perfectly elastic, what is the speed of the 110 g ball after the collision?
KEi=KEf
1/2m1v1i^2 + 1/2m2v2i = 1/2m1v1f^2 + 1/2m2v2f^2
Tried plugging it in but I don't really understand the concept so I am let with 2 final velocity. Please help.
110g < 400g so 110g should move left and 400g should move right, so does that make v2f=0?
You have two unknowns and therefore need two simultaneous equations. What else is conserved besides energy?
Momentum and kinetic energy?
Correct! So you already have one equation (conservation of energy), can you now write a second equation using conservation of momentum? You should then have a system of two simultaneous equations.
Nope, I don't understand how. There is an equation my textbook derived for perfectly elastic collisions but it is only if the second mass is at rest.
What does the principle of conservation of momentum state?
Pi=Pf mivi=mfvf
jonnejon said:
Pi=Pf mivi=mfvf
Correct, so can you now apply conservation of momentum to your problem?
So, I solved for m2vf2 in the momentum equation and plug that into the energy equation and solve for vf1 but I got it wrong.
Could you detail your steps?
solve for v2f in momentum equation:
v2f = (m1v1i + m2v2i - m1v1f) / m2
v2f = (v1i/m2 + v2i - v1f/m2)
plug it in the energy equation:
1/2m1v1i^2 + 1/2m2v2i^2 = 1/2m1v1f^2 + 1/2m2(v1i/m2 + v2i - v1f/m2)^2
solve for v1f?
Your step from the first line to the second is incorrect. Where did the m1 go?
Opps, I thought it cancels out because of the subtraction sign.
1/2m1v1i^2 + 1/2m2v2i^2 = 1/2m1v1f^2 + 1/2m2 (m1v1i/m2 + v2i - m1v1f/m2)^2
1/2m1v1i^2 + 1/2m2v2i^2 = 1/2m1v1f^2 + 1/2m2 (m1^2v1i^2/m2^2 + v2i^2 - m1^2v1f^2/m2^2)
1/2m1v1i^2 + 1/2m2v2i^2 = 1/2m1v1f^2 + (m1^2v1i^2 - m1^2v1f^2)/2m2 - m2v2i^2/2
1/2m1v1i^2 + 1/2m2v2i^2 = 1/2m1v1f^2 + (m1^2 (v1i^2 - v1f^2)/2m2) - m2v2i^2/2
(1/2m1v1i^2 + 1/2m2v2i^2)(2m2)/(m1^2) + m2v2i^2/2 = 1/2m1v1f^2 + (v1i^2 - v1f^2)
Man, this equation just getting to complicated. Am I even doing it right?
Yes it is getting rather complicated. I really can't decipher what you've written, you could use latex to make things easier to read,
Conservation of Energy
m_1v_{1i}^2+m_2v_{2i}^2 = m_1v_{1f}^2+m_2v_{2f}^2
Conservation of Momentum
m_1v_{1i}+}m_2v_{2i} = m_1v_{1f}+m_2v_{2f}
I tried doing that but it was just too messy for me. I actually found out how to do it. There are perfectly elastic collision equations in my textbook for velocities at rest. But they said you can use the Galilean transformation of velocities to make the 2nd object's velocity into zero and then find the final velocity.
Used:
v' = v - V
Thanks for your help though.
in elastic collision momentum and energy is conserved
