How Do Permanent Magnets Generate Energy in a Dynamo System?
Permanent magnets generate energy in a dynamo system through electromagnetic interactions, but they do not create energy; rather, they convert existing energy. When magnets repel each other, no energy is expended in the same way that a table supports an apple against gravity. The concept of using magnets to power a fan and subsequently a dynamo is flawed, as magnetic forces are conservative and do not result in net work being done. Any perceived motion from such a setup is misleading, as it does not produce usable energy. Ultimately, energy cannot be created or destroyed, and the system described would not yield electrical energy.
DudeWut
First off, I am new here, so please don't tear me apart too hard if I miss or misinterpret something, I'll cotton on eventually :D
As I understand it, when a permanent magnet repels an oppositely charged object, such as another oppositely charged permanent magnet, no energy is technically being used for the magnets to repel each other, as it is the same principle as putting an apple on a table. The stiffness of the table is counteracting the force of gravity's force on the apple, and that is why the table doesn't just collapse. The stiffness is from the electromagnetic interactions of the atoms making up the table, so in the end it is the EM force counteracting the gravitational force. The magnets repelling each other is caused by electromagnetic interactions.
In this case, if I were to mount negatively charged permanent magnets onto the blades of a fan, and rotate them using the repulsion of a positively charged permanent magnet, then use said fan to power a dynamo that generated electricity, where would the electrical energy be coming from? Energy cannot be created (or destroyed for that matter) so where is it coming from?
Yes, the magnets may eventually lose their magnetism due to surrounding heat and such destabilizing them, but don't magnets still work at absolute zero? In a vacuum environment at absolute zero with no outside forces that can destabilize the magnets at that moment (the friction of the fan turning would generate heat, which would radiate to the magnet and perhaps destabilize it over time) the magnets would still repel, yes? At absolute zero, in a vacuum, there isn't much energy going around that the magnet can readily store and convert to repel it's opposite. As far as I am aware there is no energy change in a magnet anyway. Where is it coming from!?
DudeWut said:
...if I were to mount negatively charged permanent magnets onto the blades of a fan, and rotate them using the repulsion of a positively charged permanent magnet
That doesn't work and videos on YouTube that appear to show the fan rotating are _all_ fake.
Magnetic force is a conservative force. Read the first paragraph of this..
https://en.m.wikipedia.org/wiki/Conservative_force
If the fan were to rotate that would be the equivalent of a particle (magnet) returning to its starting position once per revolution (eg traveling around a closed loop) so no net work is done. No work means nothing to overcome friction so it cannot rotate.
PS Welcome to the forum.
Note that:
A positively charged object ATTRACTS a negatively charged object.
A positively charged object REPELS a positively charged object.
A negatively charged object REPELS a negatively charged object.
similarly for magnetism:
North and south poles attract each other.
A north pole repels a north pole, and a south pole repels a south pole.
Ever try to pull two magnets stuck together apart?
You have to do work to do that.
The work can be recuperated by moving the magnets back together again.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
