Permutations of n taken r at a time
  • Thread starter Thread starter PiRsq
    Permutations Time
To solve P(n,3)=210, the equation simplifies to n(n-1)(n-2)=210, which can be approached through trial and error or by estimating n around the cube root of 210. The cubic equation can be solved using a general formula, although higher-degree equations lack such solutions. For P(5,r)=20, it is determined that r must be less than 5, leading to the conclusion that P(5,2)=20. This highlights the importance of understanding permutations and the relationships between n and r in combinatorial problems. Overall, the discussion emphasizes trial-and-error methods and the application of mathematical formulas for solving permutation equations.
PiRsq
How can I solve these two problems?
P(n,3)=210 and P(5,r)=20
For the first one I got up to n(n-1)(n-2)=210 but I don't know how to solve a cubic equation...And the second one I have no clue. I'd appreciate some help, thanks
Trial and error; there are very few possibilities. :smile:
Wow, its that simple? Is there any way to calculate an answer for a cubic equation?
There's a general formula for the cubic equation, and also for the quadric equation. On the contrary Abel showed there is no general formula to solve the quintic equation (or higher) and Galois showed why, inventing group theory in the process.
I see, thanks
You can "speed up" the trial-and-error process a little by noting that, since n, n-1, and n-2 are about the same, the problem is "close to" n3= 210. 53= 125 and 63= 216 so start trying with n-1= 6.
As for P(5,r)= 20, you know that r must be less than 5 so: P(5,0)= 1 (Of course, didn't really need to try that), P(5,1)= 5 (again "of course"), P(5,2)= 20!
