Peter Hammond recalls the birth of the medium-voltage drive
  • Thread starter Thread starter Windadct
    Drive
Peter Hammond discusses the innovation behind the medium-voltage drive, highlighting its significance in engineering. The use of fiber optics for isolating control signals is noted as a key advancement. Each cell in the medium-voltage setup requires its own ground and control power, showcasing numerous small innovations from the 1990s. The importance of balancing systems, such as voltage dividers, is emphasized to prevent cells from floating apart. This conversation illustrates the ongoing evolution and creativity within the field of engineering.
Windadct
What is innovation ? ... here is a great example.
I'm in this field and know this product pretty well. I though it may be interesting to both the old and new PF members...
http://www.controldesign.com/articles/2016/peter-hammond-recalls-the-birth-of-the-medium-voltage-drive/?show=all
Likes berkeman, Asymptotic and Drakkith
Very nice, thanks @Windadct -- nice touch on using fiberoptics for isolating the control signals. :smile:
Aha moments (or weekends) are one of the best parts of Engineering, IMO. :biggrin:
In in this MV cellular set up - each cell effectively has it's own ground, and has to generate it's own control power, lots of small innovations - and to think this was not that long ago (90's). Every cell's superstructure has to be isolated from the next, but then also you need balancing system - like a voltage divider, so that no one cell "floats" too far away from the others. Isolation of structures in MV systems is "fun".. haha
Likes berkeman
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
