Ph.D on mathematics or physics..?
Choosing between a Ph.D. in mathematics or physics should not be based solely on the perceived time to completion, as the duration of doctoral programs is highly variable and depends more on the specifics of the research project and individual effort than on the field itself. Current knowledge in differential equations and classical mechanics is insufficient for pursuing a Ph.D., and it is advisable to continue studying while fulfilling military commitments. The completion of a Ph.D. hinges on the successful execution of an original research project, which can vary significantly in duration regardless of the discipline.
jhooper3581
Okay, I really wanted to get a Ph.D on either mathematics or physics. I have current knowledge all the way up to differential equations for mathematics, and just classical mechanics and Principia for physics. I will go for the doctoral degree after six years (after the Navy). If I want to get a Ph.D sooner, then should I choose mathematics or physics for doctoral degree? Also, I've heard that physics takes a bit longer to problem solving than mathematics does, but anyways, any helpful replies will be appreciated.
Your "current knowledge" is not enough for either subject to pursue a Ph. D. It's not even enough for a bachelor's degree. I hope you are currently studying while you are in the Navy, before even hoping of getting into a Ph. D. program.
I think he or she is suggesting that it will take six years to complete both the undergraduate degree and any naval service committments.
You can't pick a PhD field based on 'time to completion' because this is highly variable. A PhD is awarded based on the completion of an original research project. Research is not a matter of just putting time in. Some projects go quickly. Others drag out. A funding expiration date provides additional motivation in some cases, but it doesn't guarantee that a student will finish in four years. Whether you chose a mathematics-based or a physics-based project, the time to completion will be a much stronger function of the project specifics (and your personal efforts) than the field it's in.
TL;DR Summary: I want to do a PhD in applied math but I hate group theory, is this a big problem? Hello, I am a second-year math and physics double major with a minor in data science. I just finished group theory (today actually), and it was my least favorite class in all of university so far. It doesn't interest me, and I am also very bad at it compared to other math courses I have done. The other courses I have done are calculus I-III, ODEs, Linear Algebra, and Prob/Stats. Is it a...
Yesterday, 9/5/2025, when I was surfing, I found an article The Schwarzschild solution contains three problems, which can be easily solved - Journal of King Saud University - Science ABUNDANCE ESTIMATION IN AN ARID ENVIRONMENT https://jksus.org/the-schwarzschild-solution-contains-three-problems-which-can-be-easily-solved/ that has the derivation of a line element as a corrected version of the Schwarzschild solution to Einstein’s field equation. This article's date received is 2022-11-15...
9K
