Phase Diagram of Steel with unknown C content
The discussion focuses on determining the carbon content and phase characteristics of as-cast steel with a ferrite weight percentage of 35.23%. It is established that the steel is hypoeutectoid due to the ferrite presence along grain boundaries, indicating a carbon content of less than 0.76 wt% C. The lever rule is referenced as a method to compute weight percentages, although the temperature required for its application is not provided, complicating the calculations for carbon content and phase distribution.
  • Understanding of phase diagrams, specifically the iron-carbon phase diagram.
  • Knowledge of the lever rule for calculating phase weight percentages.
  • Familiarity with the definitions of hypoeutectoid and hypereutectoid steels.
  • Basic concepts of solidification and microstructure in metallurgy.
  • Study the iron-carbon phase diagram to understand phase transitions and compositions.
  • Learn how to apply the lever rule in different temperature scenarios.
  • Research the effects of temperature on solubility limits in steel alloys.
  • Explore the microstructural implications of as-cast conditions in steel.
Metallurgists, materials scientists, and engineering students focusing on steel properties and phase transformations will benefit from this discussion.
Knife
Given that the overall weight percentage of ferrite along the grain boundaries of an as-cast steel with unknown C amount is 35.23%:
a) Identify if it is hypoeutectoid or hypereutectoid.
b) Identify the amount of carbon alloyed in the steel.
c) Identify how much ferrite and cementite are in sample.
d) Identify the amount of eutectoid ferrite.
I know that eutectoid is at 0.76 wt% C. If the wt% C is less it is hypoeutectoid, otherwise it is hypereutectoid. The problem is, the wt% C is unknown and I think I need to find that first to be able to answer a.
I'm given the weight percent of ferrite along the grain boundaries. I know there is a formula for computing the weight percentages using the lever rule, but you need to know the temperature in order to use the lever rule as far as our previous examples went, which is not given.
I really don't know how to start. The whole lecture is very muddy to me conceptually.
I don't think "as-cast" was mentioned in our lecture before, does this have any influence on the answer?
Update.
a) Since the ferrite is at the grain boundaries it can be assumed this is formed above 727 C. By inspecting the phase diagram: Hypoeutectoid begins at the austenite area, then goes to the ferrite and austenite area. Thus, the answer is hypoeutectoid.
b) I just know that the answer should be <0.76 wt% C. I still don't understand how to obtain this.
Update 2.
This is why I am stuck at b, if I use the lever rule:
[tex]W_{pro-\alpha} = \frac{0.76-A}{0.76-B}[/tex]
A is the wt% C which I don't know, and B is at the solubility line which varies with T but I also don't know T.
9K
36K
