Phase factors and Modulus Square?
6 replies · 2K views · last reply
kq6up
If I have something like:
$$\lvert \langle M \lvert \hat{L}_x+i\hat{L}_y \rvert M-1 \rangle \rvert ^2=c$$.
where ##c## is any old real number. If I undid the modulus square to find:
$$ \langle M \lvert \hat{L}_x+i\hat{L}_y \rvert M-1 \rangle=\pm \sqrt{c} $$ Would I not have to consider ##c## as being negative, positive as well as imaginary negative positive? So:
$$ \langle M \lvert \hat{L}_x+i\hat{L}_y \rvert M-1 \rangle=\pm i \sqrt{c} $$ as well.
I am trying to get to:
$$ \langle M \lvert \hat{L}_x \rvert M-1 \rangle=\frac{1}{2} \sqrt{c} $$
and:
$$ \langle M \lvert \hat{L}_y \rvert M-1 \rangle=-\frac{i}{2} \sqrt{c} $$
From Landau and Lifshitz QM 3ed page 89, and I am not following. Any tips will be appreciated.
Thanks,
KQ6UP
You need the raising and lowering operators: ## L_+=L_x+iL_y ## and ## L_-=L_x-iL_y ##. You can solve for ## L_x ## and ## L_y ## and substitute. The computations are straightforward using the formulas for the result of ## L_+ ## and ## L_- ## operating on the state ## | M > ## (or ## | M-1> ##, etc.).
That is where I started before ##\langle M \lvert \hat{L}_+ \rvert M-1 \rangle=\sqrt{(L+M)(L-M+1)}##, and I am trying to get to:
##\langle M \lvert \hat{L}_x \rvert M-1 \rangle=\frac{1}{2}\sqrt{(L+M)(L-M+1)}##
Thanks,
KQ6UP
Thanks,
KQ6UP
You can readily compute ## L_x=(L_++L_-)/2 ## . ## \\ ## ## L_- |M-1> ## will give some number times ## |M-2> ##. The matrix element ## <M|M-2> =0 ## and ## <M|M> =1 ##. Also note ## L_+|M-1>=\sqrt{(L+M)(L-M+1)}|M> ##.
This is true. However, I am still wondering about my original question. When you "undo" the square of a modulus, it seems reasonable to me that you would have a family of solutions as detailed above. Is this true?
Thanks,
KQ6UP
Thanks,
KQ6UP
Your "c" above is always positive. I think one question you are asking is might these matrix elements always contain an arbitrary phase factor of the form ## exp(i \phi) ##, and I think the answer to this is yes.
Just confirming what Charles has said above, one can always replace ##c## with ##ce^{i\phi}## as this will only impose a constant phase factor on the state. It's chosen as real positive just a matter of convention, pretty much the same case as the constants ##\sqrt{n+1}## and ##\sqrt{n}## in the raising and lowering operators in harmonic oscillator.
