Phase sensitive demodulation circuit
  • Thread starter Thread starter LM741
    Circuit Phase
A phase-sensitive demodulator is needed to recover an original signal from a modulated output generated by a linear variable differential transformer (LVDT) measuring vibrations. The user seeks guidance on designing a circuit that can separate the core frequency from the excitation frequency, which is modulated at 10 kHz. Suggestions include using a synchronous demodulator or a single sideband (SSB) receiver approach, which involves mixing the carrier frequency with the modulated signal. There is a discussion about the output signals, questioning whether both sidebands and the carrier are present or if only the sidebands emerge. The conversation highlights the complexity of building such a circuit and the need for further clarification on specific components.
LM741
hello all,
really stugglin with this one - need to build/design a phase sensitive demodulator - i.e a circuit that can recover my orginal signal...
don't suppose anyone has any idea how to go about this or some circuit diagram i could work with?
thanks
John
I think you'll need to explain what a "phase-sensitive demodulator" is in a lot more detail before we could begin to help you.
- Warren
ok - so I am using a linear variable diff transformer to measure vibrations. Such a device takes in an excitation voltage at specified frequency, let's say 10kHz. Now let's say the core is moving with a frequencey of 100Hz - my ouput will now be a modulated signal that will have frequnceies of about 10.1kHz and10.9kHz. The phase sensitive demodulater is meant to separate the the core frequency from the excitation frequency (carrier frequency). I am only interested in the frequency of the core. All i know is that the phase sensitive demodulator uses the frequency from the oscillator (that i use to generate the AC excitation voltage) to recover the orignal signal. Just stugglin to find a circuit that can do this. there are many chips that have cover all signal conditioning issues for an LVDT but this is no ood to me - i just want the phase sensitive demodulator - also called synchronous demodulator.
Thans very much
That's like a SSB receiver. Just mix the carrier frequency with the modulated signal (derived from the same carrier), that will produce the sum and difference frequencies, with appropriate filters, filter out the unwanted frequencies.
ok?? what is a SSB receiver?? is it easy to build? ill google it - then talk tomorro
thanks
So are there 3 signals coming out of this device? Both the upper and lower sidebands and the carrier or does this device act like a double balanced mixer with just the sidebands coming out?
