Why does a phase shift occur on reflection?
A phase shift of pi occurs when an electromagnetic wave reflects off a denser medium, causing the reflected wave to be out of phase with the incident wave. This shift does not imply complete destruction of the wave at normal incidence, as some energy is still reflected. The phase shift is specific to transitions from rarer to denser media, while transitions from denser to rarer do not result in a phase change. Maxwell's equations govern the behavior of electromagnetic waves at media interfaces, predicting the amplitude ratios of reflected and transmitted waves. The discussion highlights the mathematical nature of wave behavior, which can sometimes seem abstract or counterintuitive.
PhysicsStudnt
Dear Experts,
When an electromagnetic wave moves from a rarer to a denser medium or gets reflected by a mirror, it encounters a phase shift of pi or (lambda/2), in that case, the reflected wave will be out of phase with the incident wave.
I have a very basic (maybe non intuitive or even stupid) doubt regarding this. Does the above mentioned statement imply that a light wave incident at 0 degrees to the normal to a surface will be completely destroyed by its reflecting counterpart?.
I am also finding it hard to understand why the phase shift occurs only in the interface between rarer to denser and not from denser to rarer. There are explanations in terms of waves on a tied string, but in case of electromagnetic waves in which fields are fluctuating, how can we relate the behavior.
Thanking you in advance.
Science news on Phys.org
The Maxwell equations predict what happens at the interface of two media: The components parallel with the interface both of the electric field E and of the magnetic field H are the same in both media and so are the normal components of D and B.
In case of an incident wave from the first medium, it follows from these boundary conditions, that there should be a reflected wave in the first medium , in addition of the refracted one, traveling in the second medium.
Also the ratio of the amplitudes r= E(reflected)/E(incident) and t= E(transmitted)/E(incident) can be derived. At normal incidence, r=(n1-n2)/(n1+n2) where n1 and n2 are the refractive indices.
You can see that the reflected amplitude is smaller than the incident one (there is never totalreflextion at normal incidence) and in case n1<n2, the reflected wave changes sign, so its phase changes by pi. In case n1>n2, the incident wave and the reflected one are in phase.
All these are true for dielectrics, having real refractive indices. The metals are different, their refractive index is complex, and the complex refractive index determines the phase change which can be anything between 0 and pi.
ehild
It's not only Maxwell's equations that are involved here. The same thing works for mechanical waves, too. There is something annoyingly 'mathematical' and almost arbitrary about the way waves behave - but the calculations predict what we always observe. So it's a good model.
sophiecentaur said:
There is something annoyingly 'mathematical' and almost arbitrary about the way waves behave…
I find this comment intriguing. Could you please explain further what you are thinking?
I should, perhaps have put the 'annoyingly' inside the quotes. I wrote the post in sympathy for the hordes of contributors who ask for 'physical' reasons for phenomena. Waves can appear to be driven by the Maths, which many people seem to find annoying or even threatening when all they want is a simple explanation. There's a similar thing where it seems to be Statistics itself that is providing the Forces to make gases behave the way they do. Personally, I'm all in favour of a Mathematical model whenever I find it.
11K
