Phases of water coexisting at equilibrium.
Two phases of water can coexist at equilibrium under specific temperature and pressure conditions. The phenomenon occurs at the triple point, where solid, liquid, and vapor phases exist simultaneously. This unique state is defined by a precise temperature of 0.01°C and a pressure of 611.657 pascals. Understanding these conditions is crucial for applications in thermodynamics and environmental science. The concept highlights the intricate balance of phase transitions in water.
stickynote
At an equilibrium temperature, can two phases of water coexist? If so; under what conditions can this occur?
Many Thanks,
Stickynote.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 18 ·
