Phenomena of reflection of light
- Context: High School
- Thread starter thamwenyin
- Start date
The discussion revolves around the phenomenon of light reflection, specifically addressing the observed gap at the start of the reflected light in an experimental setup involving mirrors. Participants explore various aspects of reflection and refraction, as well as the implications of different mirror coatings and experimental configurations.
- Exploratory
- Technical explanation
- Debate/contested
- Experimental/applied
- One participant questions the cause of a gap in the reflected light during their experiment.
- Another participant suggests the Goos-Hänchen effect may be relevant, particularly in optical fibers, but questions its applicability in this context.
- Several participants speculate that the gap may result from the use of a card or sheet of paper blocking the incident beam, leading to an apparent absence of reflected light near the surface.
- Another participant proposes that the gap could be due to the properties of the glass and reflective coating, where light is refracted and reflected in a manner that creates the observed gap.
- Some participants discuss the role of multiple reflections and refractions in contributing to the gap, with one expressing uncertainty about how these processes interact.
- There is a suggestion that the geometry of the setup may influence the appearance of the gap, particularly if the mirror is elevated above the surface.
- One participant raises the possibility that the type of mirror (front-coated vs. rear-coated) could affect the results of the experiment.
- Another participant describes the nature of the light source as a vertical ribbon, suggesting that the gap arises from the interaction of this ribbon with the mirror's surface.
Participants express a range of hypotheses regarding the cause of the gap, with no consensus reached. Multiple competing views remain, and the discussion continues to explore various explanations without resolving the underlying questions.
Participants note that the details of the experimental setup, including the type of mirror and the method of observing the light, are crucial for understanding the phenomenon. Some assumptions about the behavior of light in the context of reflection and refraction are not fully clarified.
- 7,793
- 4,094
http://en.wikipedia.org/wiki/Goos–Hänchen_effect
AFAIK, this is a significant effect when transmission in long optical fibers is involved, but not much else.
- 12,179
- 186
Welcome to Physics Forums.thamwenyin said:I wonder why is there a gap at the starting of the reflected light when i conduct this experiment? Can anybody explain this to me? Thanks!
Can you describe your experiment a little more? Specifically, exactly how are you "observing" the light ray or beam?
- 12,179
- 186
Just a hunch.
- 10
- 0
Redbelly98 said:If I had to bet, I would guess that you are using a card or sheet of paper to see where the light beam is. When you hold the sheet near the reflecting surface, it is actually blocking the incident beam, making it appear that there is no reflected beam right near the surface. But in reality there is no reflected beam because the incident beam is blocked before it reaches the surface.
Just a hunch.
The experiment that I conducted is similar to this>>http://www.youtube.com/watch?v=LMmnuUOZ6ho&feature=related
From the video,it is obvious that there's a gap between the plane mirror and starting of reflected ray. Why does this happen? Is it caused by the glass and the coating of reflective metal in the mirror? But how?
- 2,489
- 105
thamwenyin said:Why does this happen? Is it caused by the glass and the coating of reflective metal in the mirror? But how?
It is caused by the glass and the reflective coating.Most of the light incident on the mirror enters the glass ,gets refracted towards the normal,gets reflected bythe reflective coating and emerges,after being refracted away from the normal at the surface.With the type of mirror and/or experimental set up you used you were unable to see the rays in the glass itself so this shows up as an apparent gap.Not all of the light is reflected by the coating some of it being reflected by the front surface of the mirror.In fact there are multiple reflections.If you look very carefully you may be able to see the weak reflected rays due to the first reflection from the front surface of the mirror.
- 10
- 0
- 4
- 0
- 7,793
- 4,094
thamwenyin said:The experiment that I conducted is similar to this>>http://www.youtube.com/watch?v=LMmnuUOZ6ho&feature=related
ok- I see what you are referring to.
The details of the setup are not clear in the video (I wasn't listening to any audio track)- for example, why does the light appear to pass through to the person's thumb?
If the mirror is off the table surface, the gap could appear simply from geometry- the rays of light are diverging (spreading) normal to the table, and so if the mirror is off the table surface, the reflected light won't hit the table for a short distance.
That's just a guess, tho.
- 12,179
- 186
I don't think so. If that were true, there should be a gap in both the incident and reflected rays. But if you pause the video when they show the more extreme angles, it pretty clearly looks as posted in the OP. It seems most evident when the incident and reflected beams are at 90 degrees to each other: a gap in the reflected ray, whereas the incident ray extends completely to the point where the two lines intersect.Dadface said:It is caused by the glass and the reflective coating.Most of the light incident on the mirror enters the glass ,gets refracted towards the normal,gets reflected bythe reflective coating and emerges,after being refracted away from the normal at the surface.
I'll repeat my earlier question to the OP: exactly how are you "observing" the light ray or beam?
- 10
- 0
Redbelly98 said:I'll repeat my earlier question to the OP: exactly how are you "observing" the light ray or beam?
I put the ray box and the mirror on top of a sheet of smooth white paper and observe the light ray from a plan view. I tried removing the paper and observe it on the table,the same thing happened.
- 4
- 0
- 2,489
- 105
Redbelly,How do I pause the video?I need to look at it more carefully but it seems to be a front coated mirror.On second thoughts......
- 2,489
- 105
- 12,179
- 186
To the lower left of the video frame, there is a pause button (two vertical lines in a box) and a volume control button. Pause at about 21 or 22 seconds for a good view.Dadface said:Redbelly,How do I pause the video?
- 2,489
- 105
- 4
- 0
- 30,534
- 7,516
The answer is, I think, in the simple geometry of the setup. Any of those types of demonstrations are not, in fact, using 'rays'. They are using the light coming from a vertical slit source, which is a vertical band or ribbon of light. Each patch of light on the paper is produced by light from a higher and higher part of the ribbon (If it were a single ray, it would get no further than the first few bumps and hairs on the paper). The part of the vertical ribbon of light which hits a surface silvered reflector will hit the paper immediately in front of it and there would be no gap. With a normal rear-slvered mirror, however, there is a narrow part of this vertical ribbon which enters the glass and is not reflected at the glass surface. You have to look a bit further up the vertical ribbon until you get some light that will be reflected off the rear silvering. So a small slice of the incident ribbon gets lost* in between the glass surfaces. Because it is such a shallow angle, the effect is exaggerated, the start of what we interpret as the reflected ray is not there and a small gap is seen.
*There will be some total internal reflection off the bottom glass surface which will totally lose the light (sending it upwards) that would have formed the first bit of the reflected 'ray'.
- 10
- 0
sophiecentaur said:So a small slice of the incident ribbon gets lost* in between the glass surfaces. Because it is such a shallow angle, the effect is exaggerated, the start of what we interpret as the reflected ray is not there and a small gap is seen.
When i conduct the experiment,by using different angles of incident varying from >0 to 90<,the gap still appears. Based on what you said,total internal reflection in the mirror cause the gap to manifest, but total internal reflection will happen only at certain angle, how the gap can be seen all the time with all the angles i tried?
- 30,534
- 7,516
I can't imagine the phenomenon is due to any diffraction mechanism - the gap is far too big - so it must be due to geometry.
I shall sit down (you too?) and try some multiple ray diagrams and see what happens in detail.
I could ask whether the missing bit is the same width for all angles in your experiment. If you were to use a thin (laser) beam, we'd expect the same missing portion.
- 2,489
- 105
1.The rays get refracted on entering the mirror,then reflected at the silvered surface and get refracted again on emerging from the mirror.Only the rays scattered from the paper surface are clearly visible,not those within the mirror,but the incident and emergent rays only.The result is that for non normal incidence there appears to be a gap,the incident and emergent rays being laterally displaced from each other.
2.Those parts of the rays grazing the top surface of the mirror get scattered by the mirror itself giving the impression that the incident rays are not refracted but travel on linearly by a short distance which is dependent on the angle of incidence and thickness of the mirror.
If you use a laser beam that does not graze the mirror surface or slits in the ray box which are shorter than the mirror then this should eliminate effect number two.A mirror with a white scattering coating along one edge and which should be suitably placed will show the refracted rays(ideally using a ray box because it would be awkward to get the laser lined up properly) and eliminate effect number one.Alternatively,a plastic block with one side coated can be used in place of the mirror.Such blocks are readily available.
Sophiecentaur some of our ideas seem to be similar but remember that total internal reflection can occur only on going from a more dense to a less dense medium.With this experiment only those rays which are reflected towards the mirrors edges and with large enough angles of incidence can be totally reflected.
- 12,179
- 186
Is the mirror reflective all the way to the edge of the mirror, or is there a small part of the mirror, at it's edge, that does not reflect?
Is the mirror's edge touching the paper, or is it positioned slightly off of the paper?
My thinking is, if either the mirror is not reflective close to it's edge, or if there were a small gap between it and the paper, then you would have a gap between the mirror and where the reflected ray first hits the paper.
- 30,534
- 7,516
Dadface said:There is a double effect with a rear coated mirror and with the apparatus I suspect was used and I don't think I explained myself clearly enough(posts 6 and 14).Let me try again:
1. I think the only effect of the refraction is to bring the effective position of the silvering a bit further forward.
2. Using a laser beam is not likely to show the whole 'ray picture' at the same time as different bots of the 'ribbon' show different portions of the ray picture.
3. Something also struck me, after having drawn a few diagrams. Because it's a mirror, there is inversion and it is the lower bits of the ribbon which hit the paper on the way out (edit: IN!) and the higher bits which trace out the pattern in the reflected direction.
4 Thinking in 3D, dadface, is a good idea and it certainly shows how there will have to be a gap between the end of the incidence line and the reflection line because what goes on within the glass won't be (as) visible - I still think that TIR is relevant to reducing the visibility of the paths inside the glass - it works up to 40 degrees or so. (Actually more than the critical angle, due to the bending at the front surface)
- 12,179
- 186
In this video, we don't have to wonder about front surface vs. back surface mirrors. The ray paths are pretty unambiguous.
- 12,179
- 186
And from the convex lens demo by the same person (people?):
- 1,212
- 10
- 12,179
- 186
Whatever is being used to view the beam -- apparently a sheet of paper, from what others have posted -- does not have any light from the reflected beam hitting it, within a few mm or so after reflecting off of the mirror. There is light coming off of the mirror, it is just not hitting the paper sheet right away.
- 1,212
- 10
Redbelly98 said:Whatever is being used to view the beam -- apparently a sheet of paper, from what others have posted -- does not have any light from the reflected beam hitting it, within a few mm or so after reflecting off of the mirror. There is light coming off of the mirror, it is just not hitting the paper sheet right away.
Oh...that makes more sense.
- 2,489
- 105
Snapshot two is using a base coated cylindrical lens which shows the refracted rays inside the lens and because of refraction these rays to be closer to the surface than they actually are(real and apparent depth phenomenom).This results in a real gap but it is vertical(along the lines of the normals to the top and bottom surfaces)rather than horizontal.The size of the gap seen depends on the viewing angle and for a perfect plan view no gaps will be visible the incident ,refracted and emergent rays all terminating at the edges of the lens.The video from which the snapshot is taken shows clearly that there is no visible gap for front surface reflection(see,for example 28 to 31 seconds)
- 10
- 0
- · Replies 10 ·
- Replies
- 10
- Views
- 2K
- · Replies 2 ·
- Replies
- 2
- Views
- 2K
- · Replies 21 ·
- Replies
- 21
- Views
- 4K
- · Replies 5 ·
- Replies
- 5
- Views
- 3K
- · Replies 9 ·
- Replies
- 9
- Views
- 4K
- · Replies 3 ·
- Replies
- 3
- Views
- 5K
- · Replies 2 ·
- Replies
- 2
- Views
- 3K
- · Replies 66 ·
- Replies
- 66
- Views
- 9K
- · Replies 6 ·
- Replies
- 6
- Views
- 4K
- · Replies 1 ·
- Replies
- 1
- Views
- 3K
