Photodiodes vs LEDs: Gallium Arsenide Sensitivity
  • Thread starter Thread starter jamesjd
    Leds
Gallium arsenide (GaAs) photodiodes are likely sensitive to light emitted from gallium phosphide (GaP) LEDs, which are available in green to red wavelengths. GaAs photodiodes are effective in the visible spectrum and are commonly used in solar cells. Their sensitivity can vary based on the diode's thickness and structural characteristics. Understanding the response curve of GaAs photodiodes is essential for optimizing their performance with GaP LEDs. Overall, the compatibility between these materials suggests potential applications in optoelectronics.
jamesjd
Would a gallium arsenide photodiode be sensitive to light from a gallium phopsphide LED?
Probably :
You can make GaP LEDs in green->red
GaAs photodiodes certainly work in the visible (used as solar cells) don't know their response curve and it's probably sensitive to the thickness and structure of the diode.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
