Can I Change Frequency to Increase Ejected Photoelectrons?
To increase the number of ejected photoelectrons, it is more effective to increase the intensity of electromagnetic radiation rather than the frequency. While higher frequency photons can enhance the energy of ejected electrons, they do not necessarily increase their quantity. The threshold frequency determines the minimum energy required to release electrons, and increasing frequency can lead to more photons successfully ejecting electrons. To calculate the voltage of a photoelectric cell, one can use the maximum kinetic energy of the ejected electrons and the work function, often expressed as stopping potential. A photoelectric cell functions more as a current source than a voltage source, and maintaining a clean surface on the cathode is crucial for efficiency.
brainyman89
1-if we want to increase the number of ejected photo-electrons, can we change the frequency of the electromagnetic radiation?
2-if i calculated the number of the ejected photo-electrons and the kinetic energy of each electron, how could i then calculate the voltage of this photoelectric cell?
For 1 -you need to increase the intensity, not the frequency. More energetic photons will increase the energy of the ejected electrons, but not the number.
what about the second question: if i calculated the number of the ejected photo-electrons and the kinetic energy of each electron, how could i then calculate the voltage of this photoelectric cell?
Actually, increasing the frequency of the incident radiation Will increase the number of electrons emitted. The threshold frequency is the frequency at which the least bound electrons are released. Many of the incident photons will not release a photoelectron but be absorbed. If you increase the frequency then a proportion of the incident photons will actually release electrons which wouldn't have been released by light with the threshold frequency. Einstein's Graph of Photon Energy vs Electron KE shows just the Maximum energy and there will be a distribution of energies up to that value.
then how could i then calculate the voltage of a photoelectric cell if i calculated the number of the ejected photo-electrons and the kinetic energy of each electron?
Not sure what you mean by that.
You can predict (assuming you have an accurate value for the Work Function) the maximum KE of photoelectrons. This is usually measured in terms of 'stopping potential', which is the (negative) potential that a nearby catcher plate needs to be given in order to stop a current flowing in the cell.
I think a simple photoelectric cell could be looked upon more as a current source, once the photoelectrons have started to be emitted, than as a voltage source. I don't think that a simple cell,based on the Einstein experiment would be a useful source of electrical energy - particularly as you need a pristine, clean surface on your Potassium Photo Cathode.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
