- #176
- 8,943
- 2,948
johana said:From the Wikipedia article I quoted it looks like locality in EPR experiments is defined exactly by the independence of the two data streams, which translates into prediction they should be completely random (50-50%) regardless of any absolute or relative polarizers rotation.
If that's the impression you got from the Wikipedia article, then it needs to be rewritten, because that's absolutely not true.
If random polarization is uniform then integrated average of cos^2 over 360° is 1/2, that's the same 50-50% Wikipedia is talking about. If the ratio is not 50-50% for any arbitrary (a-b) angle combination, then the theory is not local, or the experiment is not rotationally invariant.
That's not correct. Here's a local realistic model: You generate a pair of photons that are polarized at angle [itex]\alpha[/itex], where [itex]\alpha[/itex] is chosen randomly. Then, the probability of passing through a filter is [itex]cos^2(\alpha - \theta)[/itex] where [itex]\theta[/itex] is the orientation of the filter. Then the correlation [itex]E(a,b)[/itex] will be given by:
[itex]E(a,b) = \frac{1}{2\pi}\int d\alpha (cos^2(\alpha - a) cos^2(\alpha - b) + sin^2(\alpha - a) sin^2(\alpha - b) - cos^2(\alpha - a) sin^2(\alpha - b) - sin^2(\alpha - a) cos^2(\alpha - b))[/itex]
The positive terms, [itex]cos^2(\alpha - a) cos^2(\alpha - b) + sin^2(\alpha - a) sin^2(\alpha - b)[/itex], give the probability of both filters having the same result--either they both pass, or they both are blocked. The negative terms, [itex]cos^2(\alpha - a) sin^2(\alpha - b) - sin^2(\alpha - a) cos^2(\alpha - b))[/itex] give the probability that the two filters get different results--one passes and the other is blocked.
You can go through it yourself, if you know trigonometry. The answer is:
[itex]E(a,b) = \frac{1}{2} cos(2(a-b))[/itex]
which is definitely not zero, except in the case where [itex]a-b = \frac{\pi}{4}[/itex]
