brenan said:
What exactly is the definition of mass.
There is no single definition of "mass", in relativity. Instead, a variety of different kinds of "mass" have been defined, over the years. In connection with special relativity, there are (at least) the following kinds:
invariant mass (also known as "proper mass" and "rest mass")
relativistic mass
transverse mass
longitudinal mass
In general relativity there are more definitions:
Komar mass
ADM mass
(and probably some others)
Unfortunately, for historical/traditional/conventional reasons, there is no universal agreement about which one people mean when they say simply "mass."
For
most physicists who work with relativistic objects or particles nowadays, "mass" = "invariant mass". They define it via ##mc^2 = \sqrt{E^2 - (pc)^2}##, which gives the same result in any inertial reference frame (hence the name "invariant mass"). It reduces to ##mc^2 = E## in the object's rest frame, if it has one (hence the name "rest mass"). It also agrees with the mass that you measure classically when you put an object on a scale or balance beam, at rest.
The "relativistic mass" that most popular treatments of relativity, many introductory textbooks, and some physicists talk about, is usually defined as the "m" that makes the classical definition of momentum, p = mv, continue to "work" in relativity.
"Longitudinal mass" and "transverse mass" are defined as the "m's" that make F = ma "work" when the force is parallel to or perpendicular to the object's motion. "Transverse mass" turns out to be the same as the "relativistic mass" defined above.
In the early days of relativity, physicists used "relativistic mass" (and "transverse mass" and "longitudinal mass") more than they do now. But this gradually changed, whereas popular and introductory treatments did not. There's even a quote from Einstein in the 1940s which disparages the use of "relativistic mass." Someone will probably provide the exact reference.
