How does a photon reflect off a smooth surface?
  • Thread starter Thread starter aayushgsa
    Photon Reflection
Photons, despite having no mass, can reflect off smooth surfaces due to changes in momentum rather than speed. When a photon strikes a surface, its direction changes, which constitutes an acceleration in terms of velocity, even though its speed remains constant at the speed of light. Newton's third law applies, as the momentum of the photon is transferred to the mirror, allowing for phenomena like solar sails. The discussion also touches on the idea that individual photons may not retain their identity upon reflection, suggesting they may be destroyed and recreated in the process. Overall, the interaction between photons and surfaces involves complex principles of optics and momentum conservation.
aayushgsa
Hello,
I was just reading optics and I thought that if photon doesn't has mass it can't be accelerated..
If it is so then how it gets reflected off a smooth surface, why don't it just passes from the plane. As any reaction force by the plane couldn't accelerate it , it mustn't rebond as rebounding means accelerating.
Science news on Phys.org
You cannot change a photon's speed, but you can change its direction of motion, and thereby change its momentum.
Exactly. You can change the photon's energy and momentum, but the speed is the same, since the speed of light is a fundamental constant. What changes is the frequency of light (for energy) or the wavelength of the light (for momentum).
Newton's third law does apply here, and since the momentum of the photon is changed, so is the momentum of the mirror (in the opposite direction). If you had enough light, you could push the mirror with a noticeable force. This is what's behind how solar sails work.
Of course, things get iffy when you start treating photons like massless billiard balls moving at the speed of light, but unless you are really looking at an individual photon and not beams of trillions of them in barely visible laser beams, and the mirror has no features small enough to be even close to the wavelength of light, a classical perspective works often enough.
Hope this helps:)
Sorry jtbell but I don't think this is an answer for the OP. You have stated that a photon's speed can't vary, but you didn't say anything about its velocity and since velocity is a vector, simply changing the velocity's direction there is an acceleration.
Unless the photon reflected actually it's not the same photon sent to the surface...
Yes, that's my point @lightarrow
It's probably meaningless to attribute individuality to single photons, they are not as little balls; even if the mirror doesn't absorb the photon in the sense that its energy doesn't vary at all, I think the photon is actually destroyed and a new one re-created by the mirror, at least this is what vanesch suggested in this thread:
https://www.physicsforums.com/showthread.php?t=151977
