Physical Chemistry 1st Law of Thermo
The discussion centers on calculating the final temperature of 0.500 moles of N2 gas in two different containers after adding 1000 J of energy. The first container has a fixed volume, leading to a direct application of the equation ΔU = q, where ΔU equals the heat added. The second container, featuring a movable piston, requires consideration of both work done and heat added, thus using the equation ΔU = q + w. The specific heat capacity for the diatomic nitrogen is given as Cv = 5R/2, which is essential for determining temperature changes in both scenarios.
  • Understanding of the Ideal Gas Law (PV = nRT)
  • Familiarity with the First Law of Thermodynamics (ΔU = q + w)
  • Knowledge of specific heat capacities, particularly for diatomic gases
  • Basic principles of thermodynamic systems, including fixed and movable volumes
  • Study the application of the Ideal Gas Law in various thermodynamic processes
  • Learn about the implications of fixed versus movable volumes in thermodynamic systems
  • Explore the derivation and application of specific heat capacities for different types of gases
  • Investigate real-world applications of the First Law of Thermodynamics in engineering
Students of physical chemistry, particularly those studying thermodynamics, as well as educators and professionals seeking to reinforce their understanding of energy transfer in gas systems.
joseg707
Two containers each contain 0.500 moles of N2 initially at 300. K. One container has a fixed
volume, and the other container has a movable frictionless piston. If both containers are heated
by 1000. J energy, calculate the final temperature of N2 for each container.
PV=nRT
[tex]\Delta[/tex]U=q+w
Cv for a diatomic molecule is 5R/2
I don't really know how to approach this problem as no pressure or volume is given. For the first container, I realize that the volume is fixed, so no heat is lost to work. I don't really know where to go on from here though. Can I say [tex]\Delta[/tex]U=q and then set nCv[tex]\Delta[/tex]T=q=1,000?
For the second container, can I assume that pressure will be held constant as the volume of the container increases? The heat put into the system will then be converted into work as well and so [tex]\Delta[/tex]U will equal q+w. The temperature will increase, but not as dramatically as the first container. I don't know what to do from here though. I don't know which equation I should start with. If someone can point me in the right direction or correct me if I'm wrong, I'd greatly appreciate it. Thanks in advance!
  • · Replies 0 ·
