Physical meaning of geometrical proposition
A straight line in Euclidean geometry is defined as passing through an infinite number of points, but there is only one unique straight line that can connect any two distinct points. This concept is one of the fundamental axioms of Euclidean geometry, serving as a foundational principle for the discipline. The discussion highlights the challenges of accurate communication, especially for non-native speakers, in conveying complex geometric ideas. The notion that a line connects two points is a reasonable starting point for understanding geometric constructs. Overall, the discussion emphasizes the importance of clarity in mathematical communication.
Shubham Raj22
Is it true that one straight line goes through only 2 points??
If no then how ?? If yes then why??
No. A straight line goes through a lot of points. Infinitely many.
To add slightly to what @BvU said, it is true that there is only one straight line passing through a given pair of points. In Euclidean geometry, at least.
Yes, my reply was a bit corny. I understand english is not your native language and you meant something else than what the post litterally states. It shows that accurate communication isn't easy, to say the least.
In fact, this is one of the axioms (or postulates) of euclidean geometry. The first axiom, even. As such there is no proof or reason why - except that it's a reasonable thing to state. It is a starting point for a huge construct, namely geometry as we commonly know it (there are others, such as projective geometry).
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
