What Minimum Deceleration Ensures Legal Speed Over 116 Meters?
In summary, the problem involves a car traveling at 31.5 m/s through a speed trap with two strips placed 116 m apart. The driver needs to decelerate in order to reach an average speed within the 21 m/s speed limit by the time the car reaches the second strip. The equation to solve this problem would be one of the UVATS equations, based on the given quantities and the unknown variable.
shawonna23
146
A speed trap is set up with two pressure-activated strips placed across a highway, 116 m apart. A car is speeding along at 31.5 m/s, while the speed limit is 21 m/s. At the instant the car activates the first strip, the driver begins slowing down. What minimum deceleration is needed in order that the average speed is within the limit by the time the car crosses the second marker?
I have no clue on what equation to use to solve this problem or how I would go about solving this problem. Can someone please help me?
Look at the quantities you have and the one you're looking for and decide on the equation to use from those. It's one of the UVATS ones..
To solve this problem, we can use the equation v = u + at, where v is the final velocity, u is the initial velocity, a is the acceleration, and t is the time. In this case, u = 31.5 m/s, v = 21 m/s, and t = t2 - t1, where t1 is the time when the car activates the first strip and t2 is the time when the car crosses the second strip.
We also know that the distance between the two strips is 116 m. Using the equation d = ut + 1/2at^2, we can find the time it takes for the car to travel between the two strips. Since the initial velocity is 31.5 m/s and the final velocity is 21 m/s, the average velocity is (31.5 + 21)/2 = 26.25 m/s. Substituting these values into the equation, we get:
116 = (31.5)(t2 - t1) + 1/2a(t2 - t1)^2
Simplifying this equation, we get:
116 = 31.5t2 - 31.5t1 + 1/2at2^2 - at1t2 + 1/2a(t1)^2
Since we know that t2 - t1 = t, we can substitute this into the equation to get:
116 = 31.5t + 1/2at^2 - at^2 + 1/2a(t)^2
Simplifying further, we get:
116 = 31.5t + 1/2at^2 - 1/2at^2 + 1/2a(t)^2
116 = 31.5t + 1/2a(t)^2
Now, we need to solve for the minimum deceleration (a) needed for the average speed to be within the limit. To do this, we need to set the average speed equal to the speed limit (21 m/s) and solve for a. The equation becomes:
21 = 31.5t + 1/2a(t)^2
Rearranging this equation, we get:
1/2a(t)^2 + 31.5t - 21 = 0
Using the quadratic formula, we can solve for t:
t = (-
1. What is deceleration in physics?
Deceleration, also known as negative acceleration, is a measure of the rate at which an object slows down. It is the opposite of acceleration, which measures the rate at which an object speeds up.
2. How is deceleration calculated?
Deceleration is calculated by dividing the change in velocity by the time it takes for the change to occur. This can be represented by the equation a = (vf - vi) / t, where "a" is the deceleration, "vf" is the final velocity, "vi" is the initial velocity, and "t" is the time.
3. What are the units for deceleration?
The units for deceleration are typically meters per second squared (m/s²) in the SI system. In other systems, it may be expressed as feet per second squared (ft/s²) or kilometers per hour squared (km/h²).
4. How does deceleration affect motion?
Deceleration causes an object to slow down, which means it will cover less distance in a given amount of time. This can result in a decrease in velocity or a change in direction, depending on the direction of the deceleration.
5. What are some real-life examples of deceleration?
There are many real-life examples of deceleration, such as a car braking to slow down, a ball rolling to a stop, a person coming to a halt while running, or a rocket decreasing its speed during re-entry into the Earth's atmosphere. Essentially, any situation in which an object is slowing down can be considered an example of deceleration.
