Physics Gravitational Force Question
The discussion centers on calculating the ratio H/R, where H is the height above a planet's surface at which a probe's weight is 1% less than its weight on the surface. The equations for true weight (Ft) and surface weight (Fs) are established using gravitational force formulas. The user is advised to manipulate the equations by multiplying both sides by r^2 and rewriting the ratio of distances. The conversation emphasizes simplifying the expression to facilitate further calculations. The thread concludes with a request for additional guidance on completing the problem.
neoking77
At a distance H above the surface of a plane, the true weight of a remote probe is one percent less than its true weight on the surface. The radius of the planet is R. Find the ratio H/R.
Work:
Let Mp be mass of planet and Ms be the mass of space probe
(true weight) Ft = GMpM/(r+h)^2
(surface weight) Fs = GMpM/r^2
Ft = GMpMs/r^2 - GMpMs/r^2(0.01)
Ft = GMpMs/r^2 - GMpMs/r^2(0.01) = GMpMs/(r+h)^2
i don't know where to go from here
thanks in advance.
Multiply both sides by r^2 and write
\frac {r^2}{(r+h)^2}
as
\frac {1}{\left(1 + \frac {h}{r}\right)^2}
You should be able to handle the rest.
thank you very much for your help
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
