Physics Homework: A bead on wire
The problem involves a bead sliding on a wire in a vertical plane, influenced by gravity and friction. Participants are discussing the effects of these forces on the bead's velocity and kinetic energy at various points along the wire.
  • Participants are analyzing the relationship between velocity and kinetic energy at different points, questioning the effects of friction and gravity. They discuss whether the bead's speed remains constant or changes due to these factors.
Some participants have provided feedback on the original poster's attempts, suggesting reconsideration of certain statements, particularly regarding the presence of friction and its impact on speed and energy. There is an ongoing exploration of the implications of these forces.
There are constraints related to the visibility of the problem statements due to image loading issues, which may affect the clarity of the discussion. Participants are also encouraged to provide textual representations of the problems for better understanding.
Elliott98
A bead slides on a wire, which is in a vertical plane, as shown in the diagram. Gravity acts in the -y direction. The bead starts at A, moving to the right with an initial velocity v. The wire is frictionless between A and D and between F and G, but there is friction between D and F. (For each statement select True, False, Greater than, Less than, Equal to, or Not enough information to tell.http:////d2vlcm61l7u1fs.cloudfront.net/media%2F62f%2F62f71b78-00b4-43a8-a92b-de3a1b48521b%2Fphp3BwzEE.png
http:////d2vlcm61l7u1fs.cloudfront.net/media%2F87b%2F87b2fab7-a0ac-403b-89aa-426164f8224c%2Fphp6TF9ue.png
KE= (1/2)mv^2
PE = mgh
a) The bead is sliding down with gravity with no friction, so the speed will increase. Answer = True?
b) The velocity of the bead at D is higher than at F because before D, there is no friction, but after D to F, Friction is present. Because the velocity is smaller at F than D, the KE is smaller at F than at D. Answer = Greater than?
c) There is no friction present and its a horizontal surface so speed remains constant form D to E. Answer = Equal?
d) Conservation of energy. Answer = Equal
I'm not sure if these are correct. Any help would be greatly appreciated. Thanks![/B]
Hi Elliott98 and welcome to PF.
We cannot see the statements that are supposed to be True or False. The pictures did not load. Try reloading them or perhaps you can enter them by hand.
What else might affect the velocity over that segment? Would the speed at F be the same as at D if there were no friction in between?
I can't seem to be able to upload them so here they are:
a) Between A and B, the speed increases.
b) The bead's kinetic energy at D is ... it's kinetic energy at F.
c) The speeds at D and E are equal.
d) The total energy of the bead at B is ... the total energy at D.
a) Correct.
b) Think again in view of @haruspex's post#3.
c) Correct.
d) Correct.
Actually, the preferred way to post is with text rather than images of textual material.
Also, it's helpful to post full size images, so here is the one image of yours that survived - now in full size.
and your answers ...
kuruman said:
a) Correct.
c) Correct.
d) Correct.
For (c): There is friction in that segment.
Oops, I made a mistake. Thanks for pointing it out.
So I have a) True
b) Sorry, I'm a bit confused. The formula for kinetic energy is = 1/2 mv^2. So that mass at D is the same as at F so that doesn't change. For velocity, it will decrease because of friction? Or the velocity will increase because the beed is going down the slope, but friction will work against it so it will remain the same?
c) False, (because there is friction, the bead will slow down, so the speeds aren't equal)
d) Equal to.
Thanks for all the help!
You seem to be listing two possibilities there. Can you think of a third? (or a fourth).
  • · Replies 23 ·
  • · Replies 40 ·
  • · Replies 16 ·
16K
