Physics of a diver used in trolling?
  • Thread starter Thread starter Stephen Tashi
    Physics
A slide diver is a disc-like device attached to a fishing line that helps maintain a constant depth while trolling. It operates by balancing the forces of gravity, buoyancy, and drag, with drag being influenced by the diver's angle and the boat's speed. The diver's design affects how it interacts with water, impacting its drag and the angle of the line. Equations derived from the forces acting on the diver indicate that the speed of the boat influences the angles of both the diver and the line. A more comprehensive analysis may require examining the forces on different parts of the diver to fully understand its behavior in water.
Stephen Tashi
Education Advisor
What is a simplified physical model for a "slide diver" used in trolling for fish?
As I understand a slide diver, it is a small disc like device attatched to the end of a fishing line. The fishing line is attached to something on a boat and the boat pulls line through the water at a constant velocity. The purpose of the slide diver is to cause the line to float along at a constant depth and, in some uses, to make the line float off the the side of the boat instead of trailing directly behind it.
(This post is prompted by a post in the Mathematics section by harlyhar which asks how to fit an equation to some empirical data for a slide diver. https://www.physicsforums.com/showthread.php?p=3479961#post3479961 I doubt the empircal data is sufficient to supply all the variables involved, but it would help to know the symbolic form of the physics formulas.)
The plane of the disc is not necessarily perpendicular to the line. One thought is that the force exerted by the disc is due to drag and that the drag is a function of the rate of flow of water normal to the surface of the disc. In equilibrium, I think the diver remainis at contant position in a frame of refernce that moves with the boat. In this model, the net force down on the disc (due to gravity and any bouancy) plus the drag force would be balance by the tension on the line. Is that a plausible picture of what's going on?
That would be my first guess. But this is the first time I've heard of such a device, so I'm not an expert.
You said the diver keeps at constant depth. So it must be made in a certain way. The gravity plus bouyancy is a constant force upward that doesn't depend on depth or speed through water. The drag will be proportional to speed squared through water (since I'm assuming it moves through the water with relatively great speed). The angle of the plane of the diver will also affect the drag, (the perpendicular area is proportional to the drag). The depth will affect the forces on the diver only because of the angle at which the tension in the line acts.
So somehow these contributions all combine so that the diver stays at a constant depth. If we say that \theta is the angle the line makes from horizontal and \phi is the angle the plane of the diver makes from horizontal, then we have:
The total drag force is proportional to v^2 sin(\phi) (i.e. greatest when perpendicular to the water movement). I will call the constant of proportionality D (which will depend on the density of water and drag coefficient). So the horizontal component is D v^2 sin^2(\phi) and the vertical component is D v^2 sin(\phi) cos(\phi).
The total force due to the tension in the line takes whatever value is required to keep the diver traveling at the same horizontal speed as the boat. The horizontal component is: Tcos(\theta) and the vertical component is: Tsin(\theta) (where T is the total tension).
Also, we require that the vertical forces sum to zero, since we assume the diver is in equilibrium.
So we have:
bouyancy - gravity + D v^2 sin(\phi) cos(\phi) + Tcos(\theta) = 0
(where gravity is the positive value of the gravitaional force). And for the horizotnal forces:
D v^2 sin^2(\phi) = Tsin(\theta)
Combining the two equations we get either:
T(\frac{sin(\theta)}{tan(\phi)} +cos(\theta)) = gravity - bouyancy
Or, if you prefer:
Dv^2 (sin(\phi)cos(\phi) + \frac{sin^2(\phi)}{tan(\theta)} ) = gravity - bouyancy
Either of these equations give the conditions required for the diver to stay at a fixed point relative to the boat.
Note that: D=\frac{1}{2} \rho C_d (where C_d is the drag coefficient and \rho is the density of the fluid). And gravity is the mass of the diver times g. And the bouyancy is the weight of the fluid displaced, i.e. the volume of the diver times the density of the fluid times g.
So in other words, the speed of the boat restricts the angles of the diver and the line.
But it is probably more likely that the shape of the diver causes the drag to be greater at certain parts of the diver, which controls the angle of its plane.
So all the calculations I have done are not the full picture, I think. So it is not enough to just consider the forces on the diver as a whole. I reckon you need to consider forces on different parts of the diver (since the tension will act at a point and the drag will be different at different parts of the diver).
I'm not sure how I would go about calculating that, maybe someone else on this forum already knows the answer?..
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
