Physics of decceleration of rolling vehicle
The discussion revolves around the deceleration of a rolling vehicle, specifically comparing the effects of mass on the distance traveled by a skateboard or bicycle gliding without propulsion. Participants explore the influence of factors such as air resistance, rolling resistance, and the initial conditions of the glide.
  • Some participants argue that the deceleration of a person on a skateboard or bicycle is influenced by mass, suggesting that a heavier person would glide further due to greater rolling resistance.
  • Others contend that in a vacuum, where air resistance is absent, mass should not affect the distance traveled, as rolling resistance is proportional to normal force.
  • One participant emphasizes the need to specify initial conditions, such as whether both riders start with the same speed, to accurately assess the situation.
  • Concerns are raised about the role of friction in the bearings and how it may or may not depend on weight, with some suggesting that it could significantly impact energy loss.
  • Several participants discuss the mathematical derivation of forces acting on the skateboard, with some expressing uncertainty about the correct expression for acceleration on an incline.
  • One participant mentions conducting an Excel simulation, finding that deceleration rates remained the same regardless of mass, assuming a constant coefficient of rolling resistance.
  • Another participant notes that the assumption of a constant coefficient of rolling resistance is an approximation and may not hold true in all cases.
Participants do not reach a consensus on the influence of mass on the distance traveled by the skateboard or bicycle. Multiple competing views remain regarding the effects of rolling resistance, air resistance, and the conditions of the glide.
The discussion highlights the complexity of the problem, with various assumptions about resistance forces, initial conditions, and the nature of friction in play. Participants express differing views on how these factors interact, leading to unresolved questions about the relationship between mass and distance traveled.
Wesski
I've been arguing with my physics teacher about why the deacceleration of a person on a skateboard or bicycle that is gliding along the ground (without pedaling or pushing) is dependent on the mass of the person riding it (The higher mass person goes further). I say that it is solely due to air-resistance having the same effect regardless of the mass (in this situation it is a person with 100lbs of lead in a backpack vs the same person without, so no greater area). He says that even in a vacuum, the heavier person riding the skateboard/bike would glide further.
Who is correct and why?
Are we assuming that the person with the lead and the person without the lead reach the same speed before they quit pushing and begin to glide?
What is his argument/derivation? Assuming that the rolling resistance is proportional to normal force, mass would not affect distance in vacuum.
He says that it isn't really rolling resistance because the skate board has bearings which involve a lot more forces than just a ball rolling. The way I see it the resistance is still proportional to mass so the masses would still cancel out w/o air resistance yes?
You need to specify the conditions before you can think about an answer.
As already asked, what is the initial state? Do they have same initial speed or is something else?
How are the resistance forces supposed to depend on the mass of the system?
You have rolling resistance from the ground but also some friction in the bearing which may depend on weight.
A problem insufficiently defined can lead to never-ending "arguments".
The situation is the object starts on and rolls down a ramp about 1m high before gliding to a stop. Sorry for not specifying. I say that (ignoring air resistance) they would travel the same distance because:
They would have the same speed at the end of the ramp because (θ here is angle above horizontal that the ramp is):
ΣF = ma
(cosθ)(m)(g) - Ff = ma
(cosθ)(m)(g) - Crr(N) = ma
(cosθ)(m)(g) - Crr(m)(g) = ma
(cosθ)(g) - Crr(g) = a
And they would have the same acceleration at the bottom of the ramp because:
ΣF = ma
Ff = ma
Crr(N) = ma
Crr(m)(g) = ma
Crr(g) = a
The only way in my mind (barring some mistake here) that one would have a greater or lesser acceleration is if there is another force due to the friction within the bearing, which is either:
a) not proportional to the weight at all
b) is proportional to the weight, but to a different degree (i.e., √N, or N2).
Otherwise it would cancel, correct?
That still doesn't really specify the conditions. If you and your teacher treat the wheels and bearings differently then you'll get different results.
IME deformation of the wheels is a significant source of energy loss. After skating down a hill all wheels are hot. An unloaded (runaway) skateboard can roll further than a loaded skateboard - it depends on the wheel compound rating and the axle bolt torque (ie if the inner race is held solid or free to rotate about the axle). Anecdotal so take with a grain of salt.
Assuming both are the same physical size but different masses
1)
The rolling resistance force ( deemed to be constant regardless of speed ) is proportional to the mass.
( greater mass = greater rolling resistance force )
2) the air drag force is the same for both
Consider both forces negative as they oppose motion
So:
Since deceleration = force / mass
The heavier mass will have the greater deceleration.
ΣF = ma
ΣF = ma
Ff = ma
Crr(N) = ma
Crr(m)(g) = ma
Crr(g) = a
Yes, with this kind of friction they will travel the same distance.
However your expression for acceleration on the incline is wrong.
what is the normal force there?
If you assume that resistance is proportional to mass, then yes. But that is just an approximation.
Better still: Do the experiment with your teacher.
Oh whoops. The normal would be cosθ*mg and the downward force would be sinθ*mg. My mistake. However mass still cancels out.
Is it possible in some cases for additional mass to cause the coefficient of rolling resistance to be lower or higher?
Yes. Constant coefficient of rolling resistance is just an approximation.
i input this onto excel with two arbitrary masses and the deceleration rate is the same regardless of the mass.
The decelerating force = m * g * cosine (incline angle) * Crr
The accelerating force = m * g * sine (incline angle)
Juggle the Crr value until you get a net deceleration, then change the mass, the deceleration rate remains the same.
You needed excel to see this?
Yes, assuming Crr is independent of the mass, which is not exactly true in nature.
  • · Replies 49 ·
  • · Replies 27 ·
22K
12K
  • · Replies 69 ·
18K
  • · Replies 45 ·
62K
11K
