Is the Physics of the Frog Jump Important in Taekwondo?
  • Context: High School
  • Thread starter Thread starter makamo66
    Jump Physics
The discussion centers on the physics of the frog jump exercise in Taekwondo, emphasizing the importance of angular momentum, moment of inertia, and center of mass (COM) in optimizing jump performance. Participants clarify that swinging the arms forward contributes to gaining momentum, which aids in the jump's effectiveness. The relationship between COM height and jump distance is explored, revealing that lowering the COM can enhance the jump's horizontal distance despite reducing vertical height. The conversation also touches on the mechanics of energy conservation during jumps, particularly in relation to the long jump and high jump techniques.
  • Understanding of angular momentum and moment of inertia
  • Familiarity with center of mass concepts in biomechanics
  • Basic knowledge of energy conservation principles in physics
  • Experience with sports performance analysis techniques
  • Research the physics of jumping techniques in Taekwondo
  • Explore the role of center of mass in athletic performance
  • Study the mechanics of energy conservation in sports
  • Investigate the effects of arm movement on jump dynamics
Athletes, coaches, sports scientists, and anyone interested in the biomechanics of jumping and performance optimization in martial arts and track and field events.
makamo66
I'm trying to understand sports physics and I have a question about an exercise we do at my taekwondo studio. For the line drills, we do something called the frog jump where you jump forward as much as you can with both legs. Everyone swings their arms forward to gain momentum. What does this mean physically? Are we shifting the angular momentum to the arms? Are we increasing our moment of inertia? Is the change of the center of mass relevant?
An interesting question reminds me of the Mark Twain story The Celebrated Frog of Calvaras County
https://twain.lib.virginia.edu/projects/price/frog.htm
A related activity is the long jump whose physics is similar
https://sites.google.com/site/thelongjumpproject/the-science-of-long-jumping
Here's a study on jumping and swinging yout arms
https://iopscience.iop.org/article/10.1088/1742-6596/2071/1/012018/meta
and this one on vertical jumps
https://www.topendsports.com/testing/vertical-jump-physics.htm
You are gaining C of Mass momentum in the desired direction before you need to use your legs. Every little bit helps. Also it makes you tip forward so you start from a little further forward. Every little bit helps
You are also buying a tiny bit of time for the muscles to ramp up from zero force to maximum force.
I appreciate all of the links. I read all of them. I also ordered the book by JG Hay from the bibliography of the googles site link from Thriftbooks for about $5. I still have a question though. If you print out the google site so that you see page numbers, there are comments on page 4-5 that I don't understand. The paper says that the athlete during the transition from run up to take off begins to lower his center of mass. As a result of lowering the COM, the take off height is decreased. I thought the idea was to increase the take off height so that one jumps further and not decrease it. What am I misunderstanding?
The runner is moving in a parabola, so I guess the jump will be longer the less tall it is.
What I understood from the links you gave me is that the long jump would represent a rotation and the moment of inertia (MOI) would become larger when the arms are extended while jumping. Since angular momentum is conserved, the angular velocity would decrease and the larger MOI would prevent too much rotation. This however doesn't make sense to me because I don't see how the jump can be considered to be rotational.
This is intuitive rather than analytic.
Jumping from a stop involves gaining purchase from the floor.
Use of the arms rather than leaving them dangling at the side takes part in the forward movement. A contribution.
CAVEAT: I have not looked at the literature.
The question here is one of physiology. I presume the takoff height is dictated only by the length of your legs after you straighten up. If you crouch down the legs will provide force (presumed invariate) over a longer distance. Bigger energy.
I seem to remember reading that, for long jump, you need your CM to be as high as possible but, for high jump, you need your CM to be as low as possible. An over simplification, perhaps but.
I guess it's because the length you can travel will depend on the time you are 'in the air' but to jump high, you will have your CM actually below the height of the bar. Hence the body curve in the Fosbury Flop and the pole vault.
I think the simplest explanation is that kinetic energy (K) increases as potential energy (U) decreases because of the conservation of mechanical energy: E = K + U.
U = mgh_com where h_com is the height above the ground of the jumper's center of mass.
It depends on the proportions of the individual body. Power / Weight (we mean Mass, really) ratio is a factor and also the mechanical advantage of the leg (lever) bones etc. Any answer to the OP must really relate to one particular jumper.
Only whilst the person is actually not in contact with the ground can you say that the path of the Centre of Mass is a parabola. Initiating the jump will involve optimising the vertical and horizontal velocities achieved (as with most ballistics problems).
Your arms are given both vertical and horizontal momentum at the start. Afair you use the arms to 'pull yourself up' as you're in free fall. I'd say they start off moving upwards and forward and, on impact with the floor, they are moving down and backwards. I don't know if the exercise has an actual name but frog jump performance can be improved by carrying an appropriate size of kettle bells to increase the effective mass of the arms. With that method, one is seriously aware of the feeling of pulling yourself towards the kettle bells - they're like free ballistic energy which was stored before you took off..
  • · Replies 60 ·
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 35 ·
