Physics-Young's Double Slit Problem
  • Thread starter Thread starter frankene
    Double slit Slit
The problem involves calculating the distance between the third-order red and yellow-green fringes in a double-slit experiment. The slits are 0.143 mm apart, with red light at 665 nm and yellow-green light at 565 nm. After calculating the angles for both wavelengths using the formula Theta = sin-1((m*lambda) / d), the user found the positions on the screen. The initial answer of 0.005 m was incorrect due to a miscalculation in the final conversion, which should have been 4.804 mm. The user successfully corrected the error and expressed relief at resolving the issue.
frankene
Hello! I am stuck on a problem that seems so easy. The question is:
Two slits are 0.143 mm apart. A mixture of red light (wavelength = 665 nm) and yellow-green light (wavelength = 565 nm) falls on the slits. A flat observation screen is located 2.29 m away. What is the distance on the screen between the third-order red fringe and the third-order yellow-green fringe?
I solved for Theta for both red light and the yellow-green light. (m = 3)
Theta = sin-1((m*lamda) / d)
Red: Theta = sin-1((3 * 665e-9) / .143e-3) = .799 degrees
Yellow-green: Theta = sin-1((3 * 565e-9) / .143e-3) = .679 degrees
From there I solved for the distance and subtracted the two:
y = L * tan theta
Red: y = 2.29 * tan(.799) = 0.032m
Yellow-green: y = 2.29 * tan(.679) = 0.027m
I get an answer of 0.005m but the site says my answer is wrong. Any hints as to what I am doing wrong?
Thank you for any help!
try inputting your answer to the same degree of accuracy as the slit seperation, try 4.804 mm
Thank you! It had to be in meters so it took 4.804e-3 meters! I am glad it was an easy fix. I thought I had a grasp of this concept and I was frustrated when I couldn't get the correct answer.
Thank you again!
10K
