Picard Iteration, with a 2nd order ODE
  • Thread starter Thread starter ][nstigator
    2nd order Ode
To perform Picard iterations on the second-order ODE y'' = 6y^2 with initial conditions y(0) = 0 and y'(0) = -2, it is essential to transform the equation into a first-order system. This can be achieved by substituting p = y' and recognizing that y'' can be expressed as dp/dy. By doing so, the problem simplifies into a format suitable for applying Picard iterations, allowing for the iterative solution process to commence. Understanding this transformation is crucial for effectively tackling the problem. The discussion emphasizes the importance of substitution in solving higher-order differential equations using Picard's method.
][nstigator
Ive been told to perform 2-3 Picard Iterations on the following problem
y'' = 6y^2
With initial conditions:
y(0) = 0
y'(0)= -2
In class we've gone through how to perform picard iterations and it has been easy so far... however this is the first time it has had a second order term at the front. Through internet searches and reading our given notes, I am still not sure how to treat this so I can't really start to try and solve it...
Would anyone be able to give me a nudge in the right direction?Thanks in advance
It's just substitution, i.e f(y, y', y'')-> f(y, p, pdp/dy).
You assume there exists a p: p = y', pdp/dy = y'' and at the end you back substitute for y. This transforms a second order ODE into a first order ODE.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
