Piezoelectric effect- tube scanner
1 reply · 2K views
solas99
Hi,
i have been working on this problem for a while. i just need some guidance.
the question is: design a ztube scanner suitable for displacing ±1 micron displacement at 200V.
i am using this equation:
ΔL=([d]_{}[/31]×V×L)/t
ΔL=(d31 ×L×V)/t
ΔL=change in length = 1micron
d31=piezo strain constant (usually in pico range [10]^{}[/-12]
V=applied voltage
L=length
t=thickness (for a tube-- Outer diameter - inner diameter (OD-ID))
Rearranging the equation:
[ΔL]\frac{}{}[/V]=[L]\frac{}{}[/t×[d]_{}[/31]]
ΔL/V= L/(d×d31)
∴[ΔL]\frac{}{}[/V]=1micron/200=5nm/v
Im currently using this link.
http://www.physikinstrumente.com/en/products/prdetail.php?sortnr=400800.00
I am trying to solve it by,
choosing V=200V
ΔL= 1micron
∴[ΔL]\frac{}{}[/V]=
ΔL/V=1micron/200=5nm/v
how do i proceed after this step? i tried picking a value for [d]_{}[/31]=1.27[10]^{}[/-12]
but then i got stuck on picking realistic diameters for the piezo tube.
I am also wondering is the d31 chosen arbitrary, or its specific to the material being used, and so is it a parameter i can't control in the equation.
Usually d31 is given in pico scale.
L=1-70mm
Max diameter__ OD=78mm, ID=70mm
MIn diameter__ OD=2mm, ID0.8mm
d31= ?
i might be missunderstanding the question or equation.
thnks
d31 (and d33) are material parameters. You have to know the value for the material that you are using.
