Philosophaie said:
I am learning about General Relativity. The planetary orbits can be calculated with more precision especially Mercury. I am stuck on how to get from the Schwarzschild Metric:
a four variable Differential Equation
to a radius(r,theta,phi,t) and velocity(r,theta,phi,t) of a single planet in an ecliptical orbit around a single sun in a somewhat inertial space.
Any hints or suggestions would be helpful!
This might the sort of thing you are looking for
http://www.fourmilab.ch/gravitation/orbits/
I will try and simplify the equations given on that website to hopefully make things a bit clearer. That website uses units such that G=c=1
The first equation is for effective potential (V):
V = \sqrt{\left(1-\frac{2M}{r}\right) \left(1+\frac{L^2}{r^2}\right) }
where L is the angular momentum per unit mass of the test particle and M is the mass of the central massive gravitational body. V is a function of L and r. M and L are constants for a given test particle in free fall following a geodesic. The instantaneous radius of the particle from the central body is r.
The radius of the particle from the centre evolves in proper time according to:
\frac{dr}{d\tau} = \sqrt{E^2 - V^2}
where E is the potential energy of the particle at infinity which is also a constant for a given particle following a geodesic. It can be seen from the above equation that if dr/dtau is zero at infinity then V is equal to E at infinity.
Angular motion about the centre of attraction in terms of proper time is then:
\frac{d\theta}{d\tau} = \frac{L}{r^2}
Again it can be seen that the value of V at infinity is independent of L because d\theta/d\tau always goes to zero at infinity.
Now if you want the equations in terms of coordinate time rather than proper time the website gives the conversion factor as:
\frac{dt}{d\tau} = \frac{E}{(1-2M/r)}
Now the above indicates that the ratio of coordinate time to proper time is only a function of radius and independent of the velocity of the particle, but I suspect this is just an approximation that uses the assumption that the particle is moving at sub relativistic speeds such that velocity time dilation effects are negligible. Maybe one of the more knowledgeable people here could confirm that?
You indicate an interest in stable and unstable orbits. These are found from differentiating the effective potential and then solving for dV/dr = 0 to find the maxima and minima to obtain the radii of the possible circular orbits:
r_{circular} = \frac{L \left(L \pm \sqrt{L^2 - 12M^2}\right)}{2M}
where the smaller value is the unstable circular orbit on a knife edge effective potential peak and the larger value is a stable orbit in an effective potential valley. If the angular momentum L^2 is less than 12M^2 there is no stable orbit and the particle will reach the surface of the gravitational body.
Hope that helps some.
