I Planets or stars that are composed entirely out from Dark Matter.
The discussion centers on the possibility of stars or planets composed entirely of dark matter (DM). It is argued that DM cannot lose energy, which prevents it from collapsing into celestial bodies like stars or planets. The concept of early Universe dark stars is mentioned, but these are predominantly made of regular matter rather than pure DM. The inability of DM to undergo energy transformations necessary for the formation of larger structures is emphasized. Ultimately, the consensus is that stars and planets made entirely of dark matter are unlikely to exist.
MathematicalPhysicist
Is there a possibility that there are stars and planets that are composed entirely of DM?
How would we detect such stars or planets?
Well, I am not sure about stars, as the definition of a star depends on its fuel that it uses, I guess.
Astronomy news on Phys.org
No. Dark matter has no way of getting rid of enough energy to collapse that far. There is the concept of an early Universe dark star where DM annihilation prevents further collapse. Even these objects are predominantly matter.
How much energy does it need to get rid of in order to collapse to one of these celestial bodies?
The problem is that DM cannot lose energy. For instance, think two masses (baryonic) that are colliding with each other. If they make an inelastic collision then they will lose some energy which means that kinetic energy of the particles transforms into heat or etc. Now, they are moving as one piece.However if DM is made from particles, according to the observations, they cannot lose their energy via heat. This implies that they cannot combine with each other to create bigger objects. Because this process needs an energy transformation from kinetic energy to heat, which DM particles are not capable of.
Likes MathematicalPhysicist
Arman777 said:
However if DM is made from particles, according to the observations, they cannot their energy via heat. This implies that they cannot combine with each other to create bigger objects. Because this process needs an energy transformation from kinetic energy to heat, which DM particles are not capable of.
Contrary to your signature, DM don't connect... :-)
Likes Arman777
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
