Plank & Bullet Experiment: Questions Explained
  • Thread starter Thread starter Infamo
    Bullet
Infamo
I don't know if you guys are fimiliar with this expiriment so I'll describe it first. Let's say that there's a plank(1km and at rest with respect to the plank) away, and I launch a bullet at the plank and 1,000km/sec, and exactly one second later, the bullet hits the plank. Now, the depth at which the bullet travels into the plank, is going to depend on its momentum. Now let's say that there is a spacecraft moving perpindicular to the bullets trajectory at very high speed(gamma factor of 10). The expiriment states, that the observer in the spacecraft is going to view the bullet taking 10sec to hit the plank instead of 1sec as observed by the stationary(with respect to the plank) observer because of time dialation(which I understand).
Now here are my questions.
1.) If your going 1,000km/sec, wouldn't it take a lot less then 1sec to travel 1km.
2.) i thought that you can only experience time dilation and space concraction in parellel reference frames.
thanks in advance
Keep in mind, i only started learning relativity 4-5weeks ago and I'm only a high school senior.
It should take less than 1 s. It might be a misprint.
I think it is similar to the train-light experiment where a light beam is thrown vertically up in a carriage in a moving train. The observer in the train observes a straight line path while the observer outside the train moving with respect to train observes a slanted path of the light. You can calculate time-dilation via it.
Just replace the light with the bullet, remove the train and instead of it, move the platform. Time dilation will occur.
btw, length contraction will occur parallel to the direction of motion. Never heard of the time part though but I might be wrong.
Incidentally what are "parallel" reference frames. I haven't studied relativity much as I am only a sophomore in HS. Could you explain?
For the observer at rest wrt (with respect to) the plank, the distance is one km and the bullets velocity is 1000m/sec and so the bullet strikes the plate in one second.
For the spaceship observer, the distance is 1 km and the bullets speed is 1000m/s (you are correct about distances and velocities perpindicular to the motion not having relativistic corrections) so he sees the bullet hit the plank after 1 sec.
At the instant the bullet hits the plank, the observer on the ground sees his clock read 1 sec and the spaceship clock read .1 sec (1/gamma factor [10]).
At the instant the bullet hits the plank, the observer in the spaceship sees his clock read 1 sec and the grounds observer's clock read .1 sec (1/gamma factor [10]).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
