Please check my proof (in progress)
  • Thread starter Thread starter jhudson1
    Proof
The problem involves proving the formula for the sum of products of consecutive integers, specifically that (1*2) + (2*3) + (3*4) + ... + n(n+1) equals \frac{n(n+1)(n+2)}{3} for every positive integer n, using mathematical induction.
  • Participants discuss the structure of the proof and whether the notation is appropriate. Questions are raised about the validity of altering the left-hand side to match the right-hand side. There are suggestions to expand both sides of the equation to check for consistency.
Some participants have provided guidance on the induction step and have pointed out potential issues with the original poster's approach. There is an ongoing exploration of the algebra involved, with participants noting discrepancies in terms and suggesting revisions to the proof structure.
There are indications of confusion regarding the algebraic manipulation of terms, particularly concerning the presence of a cubic term that does not seem to match on both sides of the equation. The original poster expresses a desire to improve the clarity of their mathematical writing.
jhudson1
Prove that (1*2) + (2*3) + (3*4) + ... + n(n+1) = [tex]\frac{n(n+1)(n+2)}{3}[/tex] for every positive integer n
**edit: using mathematical induction**
In section 3 I have posted my work so far. the k^3 term is bugging me, I'm not sure how this is going to play out and if I made a mistake. I have two questions:
1) Is my notation alright? Does it look like a proof should look?
2) Can I alter the left hand side of the proof and make it match the right hand side, or should I only be working on matching the right hand side to the left hand side?
Thanks
3. Attempted Solution
You should expand both sides and see if they match. But they won't. There is a problem with the term you are adding to the right hand side. Could you take another look at it and see if you can see what's wrong with it?
Thanks
That copy of your work is hard to follow, also hard to read. Here it is below/
Basically for the induction step you need to prove that
[itex]\displaystyle <br /> (1\cdot2) + (2\cdot3) + (3\cdot4) + ... + k(k+1)+(k+1)(k+2)=\frac{(k+1)(k+2)(k+3)}{3}<br /> [/itex]​
follows from assuming that
[itex]\displaystyle <br /> (1\cdot2) + (2\cdot3) + (3\cdot4) + ... + k(k+1)=\frac{k(k+1)(k+2)}{3}[/itex]​
is true.
It doesn't look to me that this is what you've done.
With that assumption, add (k+1)(k+2) to both sides. See what you can work out.
Yes, I'll do that right now
Just worked the problem again and had a similar issue. SammyS I just now see your response. I will try it once more tonight and if I can't figure it out I'll ask my professor tomorrow.
It seems like [tex]k(k+1) = \frac{k(k+1)(k+2)}{3}[/tex]
means
[tex]k(k+1)+(k+1)((k+1)+1) = \frac{k(k+1)(k+2)}{3}+(k+1)((k+1)+1)[/tex]
but whenever I try to expand it I end up with a cubed term on the right hand side that I can't account for on the left hand side. Maybe it's an algebraic mistake? (Maybe not!)
I'll post another version tonight or tomorrow and hopefully it will be easier for you to follow. I'm interested in making my mathematical writing more legible for sure.
Your statement of induction was almost right. You had (k+1)(k+2)(k+3)/3=k(k+1)(k+2)/3+k(k+1). Replace the last term k(k+1) with (k+1)(k+2) and you should have it. You see why you have to make that change, right?
means ...
[itex]\displaystyle k(k+1) \ne \frac{k(k+1)(k+2)}{3}[/itex]
All you need to show is that [itex]\displaystyle <br /> \frac{k(k+1)(k+2)}{3}+(k+1)(k+2)=\frac{(k+1)(k+2)(k+3)}{3}[/itex]
  • · Replies 22 ·
  • · Replies 24 ·
