Please explain this question to me (F2 field)
  • Thread starter Thread starter Suy
    Explain Field
The discussion revolves around solving specific mathematical problems related to the field F2 and polynomial equations. The first question regarding a system of equations over F2 is confirmed to be false, as it does not yield exactly 2n−m solutions. The second question about the polynomial x^2 + x + 1 reveals that it has no roots in F2. For the third question, participants discuss identifying cube roots of 8i, with the correct answers being C, D, and E, and clarify the method of checking each option. There is confusion about the notation and concepts, particularly regarding F2 and cube roots, prompting requests for further explanation.
Suy
Please explain these question to me ...
1)A system of m equations over F2 in n
unknowns has exactly 2n−m solutions.
• A. True
• B. False
answer: false
2)How many roots x \in F2 does the polynomial
x2+x+1 have?
answer:0
3)Which of the following is a cube root of 8i? (Choose all correct answer)
A. sqrt(3)−i
B. −sqrt(3)−i
C. sqrt(3)+i
D. −2i
E. −sqrt(3)+i
answer: sqrt(3)+i( i think there is more?)
I have the answer, but I don't understand
also, those stuff is not in my textbook and the prof didn't give much example
... please help
Let's start the second and third questions, since they're more straightforward. For b, there are only two possible roots that you can check don't work. Do you know how to do this?
For c, can you just check whether each option is a cube root of 8i directly?
"b" you mean question 2?
No ,I have no clue... I don't know to cube root i...
The third question answer is come from wolfram..
By checking, Do you mean i cube every answer to see if it is equal 8i?
actually,I don't understand what's F2 is ...
Right, by b I meant the second question and c the third question
F2 is just the field of two elements. It's the same thing as \mathbb{Z}/2\mathbb{Z}, the integers modulo 2.
If x is a cube root of 8i, then x3=8i. So can you check whether the five options given are cube roots of 8i?
answer is C,D,E, but is there a easy way to do it??
for question 2, I know there is no solution, but the question say x \in F2 confused me
And what about question 1 please help me
edit:
If z/2z, is that mean (x+iy)/(2(x+iy))?
Thank you so much!
  • · Replies 22 ·
