Please hel with Mastering Physics, very lost in magnetism
The discussion focuses on determining the point along the x-axis where the magnetic field is zero due to two parallel wires carrying currents. The first wire carries a 6.0A current and intersects the x-axis at x = -2.0 cm, while the second wire carries a 3.5A current and intersects at x = +2.0 cm. The magnetic field is zero at a specific point depending on whether the currents are in the same or opposite directions. The original poster successfully solved the problem after initial uncertainty.
  • Understanding of magnetic fields generated by current-carrying wires
  • Knowledge of the right-hand rule for determining magnetic field direction
  • Familiarity with superposition principle in electromagnetism
  • Basic algebra for solving equations involving magnetic fields
  • Study the Biot-Savart Law for calculating magnetic fields from current-carrying conductors
  • Learn about the superposition of magnetic fields from multiple sources
  • Explore the effects of current direction on magnetic field interactions
  • Practice problems involving magnetic fields from parallel wires with varying currents
Students of physics, particularly those studying electromagnetism, and anyone preparing for exams involving magnetic field calculations.
rk2930
A long wire carrying a 6.0A current perpendicular to the xy-plane intersects the x-axis at x=−2.0cm. A second, parallel wire carrying a 3.5Acurrent intersects the x-axis atx=+2.0cm.
At what point on the x-axis is the magnetic field zero if the two currents are in the same direction?
Express your answer using two significant figures.
At what point on the x-axis is the magnetic field zero if the two currents are in opposite directions?
I am not sure how to get started
nvr mind i solved it :)
