Understanding Doping & Depletion Zone Formation
Doping in semiconductors involves adding impurities to modify electrical properties, with three-valence electron dopants creating holes that act as positive charge carriers. The formation of a depletion zone occurs when these holes lead to a region devoid of free charge carriers, affecting the material's conductivity. The behavior of atoms in this zone can involve polarization, influencing the electric field within the semiconductor. Visual aids, such as animations, can help illustrate the depletion layer's dynamics under various conditions. Comprehensive resources, including textbooks and Wikipedia articles, provide deeper theoretical insights into these concepts.
Bassalisk
Can someone explain to me in detail formation of depletion zone and doping. I thought i understood this but it confused me when it came to this depletion zone.
If u dope silicone with a substance with 3 valence electrons this forms a hole right? How does atom then behave? Does it polarize it self or?
THanks
This is going to be a really long answer. People have literally written textbooks on the subject.
If you want help visualizing what the depletion layer looks like with different doping and applied biases I think this animation is pretty neat. (you can make negative voltages too)
http://cleanroom.byu.edu/pn_animation.phtml
If you just want some basic theory backed up by a little math the wikipedia articles are pretty good and I would recommend starting there.
thanks
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
