Point Charge Check? Point Charge Check!
The discussion revolves around a physics problem involving a point charge in equilibrium within a uniform electric field. The original poster presents their calculations and seeks assistance in identifying potential mistakes in their approach to determining the charge's magnitude and sign.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculations related to the angle of the string and the resulting forces acting on the charge. There is an exploration of different equations that can be used to relate tension, electric force, and gravitational force. Some participants question the accuracy of the angle used in the calculations and suggest alternative methods for solving for the charge.
The discussion is ongoing, with participants providing insights and alternative approaches. Some guidance has been offered regarding the use of trigonometric relationships to simplify the problem, but there is no explicit consensus on the correctness of the original answer or the provided solution.
Participants note discrepancies in the calculated angle and the resulting charge, indicating a potential misunderstanding of the problem setup. There is also mention of the original poster's uncertainty due to a lack of recent experience in physics and mathematics.
Fused
Point Charge Check!?
Hi, I' did this problem but for some reason I'm not getting the right answer. If you could check to see where I made my mistake I'd really appreciate it. Thanks!
The problem:
A poitn charge (m=1 g) at the end of an insulating string of length 55 cm is observed to be in equilibrium in a uniform horizontal electric field of 12000 N/C where the pendulum's position is as shown in the figure, with the charge 12 cm above the lowest (vertical ) position. If the field points to the right, determine the magnitude and sign of the point charge.
My Answer:
I know the charge is positive because it is repelled by the electric force.
Because the system is in equilibirum, I know that
Ftx = Fe (force of the elctric field)
Fty = mg
Fty = mg
= (.001 kg) (9.8)
=.0098
To find Ftx we need the angle.
theta = invscos (43/53)
theta = 35.77
Fty = Ft cos (35.77)
.0098 = Ft cos (35.77)
Ft = 0.012078
Ftx = 0.012078 sin 35.77
Ftx = 0.00706
Fe = 0.00706
Fe = qE
0.00706 = q * 12000
q = 5.88 * 10 ^-7
Correct Answer is : 7.8 * 10 ^-7
The only mistake I can see is that you got the angle slightly wrong. (I get 38.6 degrees.)
An easier way of solving this is to consider these equations:
[tex]T sin\theta = E q[/tex]
[tex]T cos\theta = mg[/tex]
You can then combine them to solve for q without needing to first find the tension (T):
[tex]q = mg tan\theta /E[/tex]
My answer does not agree with the one given as correct.
thanks docAl
it should be invcos(43/55) to get 38.57 degrees.. Hm. but still not the right answer.
I would say that the answer given is incorrect.
I have the same problem right now, but where I haven't had Physics or Math in a few years, I don't understand this part. I get how [tex]T sin\theta = E q[/tex], and I can get [tex]T cos\theta = mg[/tex], but how can these be combined to solve for q? I feel like I am missing something between the two equations and the final equation solving for q.
The best I can figure out is because [itex]\frac{T sin\theta}{Eq}[/itex]=1, and [itex]\frac{T cos\theta}{mg}[/itex]=1, we can do ([itex]\frac{T sin\theta}{Eq}[/itex])*([itex]\frac{T cos\theta}{mg}[/itex])=1, then solve for q?
Divide one equation by the other:
[tex]\frac{Tsin(\theta)}{Tcos(\theta)} = \frac{Eq}{mg}[/tex]
then simplify by the obvious steps :smile:
I just don't follow the reasoning as to why this is possible. I realize its the easier way to solve for q, but why is this possible?
You can always divide both sides of a given equation by equal values (provided you don't divide by zero!). And the thing about equations is, one side is always equal to the other. So dividing one equation by another in the way shown above is both correct and expedient :smile:
Thanks for the help and explanation!
12K
